[QGIS-Developer] Exe size mismatch
Sachin Kumar surveykshak at gmail.com
Mon May 4 05:12:08 PDT 2020
I have compiled on MSVC 2015, Windows 10. Till compile and install as in
C:/OSGeo4w/apps/qgis-test and run successful from cmd prompt.
When I tried to package it using perl creatensis.pl, it gives error
qgis_app.dll
Error loading QGIS
Oops, looks like an error loading QGIS
Details:
Could not load qgis_app.dll
Windows Error: The specified module could not be found.
Help:
Check C:\Program Files\QGIS 3.12\bin\qgis-bin.env for correct environment
paths
What could be wrong?
Regards
Sachin
On Mon 4 May, 2020, 3:21 PM Andreas Neumann, <a.neumann at carto.net> wrote:
> Hi Sachin,
> You probably used different compile options and then it would be logical
> to me that the size of the exe is slightly different.
> Why do you worry?
> Andreas
> Am 04.05.20 um 11:48 schrieb Sachin Kumar:
> Hi, I am compiling QGIS 3.12 successfully. It is notice that my qgis.exe
> size 196KB where as when I installed QGIS 3.12 x64, its qgis-bin.exe size
> is 111KB.
> Any reason?
> Regards
> Sachin
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200504/71c68987/attachment.html>
More information about the QGIS-Developer mailing list
