[QGIS-Developer] Exe size mismatch
Nathan Woodrow
madmanwoo at gmail.com
Mon May 4 06:57:25 PDT 2020
The same thing just depends on the build options. For the windows nightly
builds, you will end up with stuff like qgis-dev-bin.exe and qgis-bin.exe
depending on what versions you have installed. I started the work Jurgen
finished it off for me.
Like Andreas said the size difference is simply the different build
options, one thing different and it's going to be different.
The Could not load qgis_app.dll normally means it can't find something that
qgis_app.dll is needing to load, could be Qt, could be GDAL or anything
that is loaded really. It's a tricky one to debug and I have never run the
package scripts for QGIS on Windows so can't help there sorry.
- Nathan
On Mon, May 4, 2020 at 10:23 PM Régis Haubourg <regis.haubourg at gmail.com>
wrote:
> Hi,
> qgis.exe and qgis-bin.exe are not the same beasts. Qgis.exe is a wrapper
> for the real exe file, passing additional .var values to the exe.
> IIRC it was done by Nathan to allow QGIS to be pinned in Windows taskbar
> correctly.
> Please correct me if I am wrong
> Le lun. 4 mai 2020 à 14:12, Sachin Kumar <surveykshak at gmail.com> a écrit :
>> I have compiled on MSVC 2015, Windows 10. Till compile and install as in
>> C:/OSGeo4w/apps/qgis-test and run successful from cmd prompt.
>> When I tried to package it using perl creatensis.pl, it gives error
>> qgis_app.dll
>> Error loading QGIS
>> Oops, looks like an error loading QGIS
>> Details:
>> Windows Error: The specified module could not be found.
>> Help:
>> Check C:\Program Files\QGIS 3.12\bin\qgis-bin.env for correct environment
>> paths
>> What could be wrong?
>> Regards
>> Sachin
>> On Mon 4 May, 2020, 3:21 PM Andreas Neumann, <a.neumann at carto.net> wrote:
>>> Hi Sachin,
>>> You probably used different compile options and then it would be logical
>>> to me that the size of the exe is slightly different.
>>> Why do you worry?
>>> Andreas
>>> Am 04.05.20 um 11:48 schrieb Sachin Kumar:
>>> Hi, I am compiling QGIS 3.12 successfully. It is notice that my qgis.exe
>>> size 196KB where as when I installed QGIS 3.12 x64, its qgis-bin.exe size
>>> is 111KB.
>>> Any reason?
>>> Regards
>>> Sachin
>>> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200504/6937f189/attachment.html>
