[QGIS-Developer] GeoPackage - where are we -where do we go
Matthias Kuhn matthias at opengis.ch
Fri May 8 03:43:23 PDT 2020
Hi Andreas
Thanks for also pointing out this question. I would like to completely
focus on b) for now to not disperse the discussion too much.
If it comes down to unresolvable problems we can still go for d).
But let's keep that for later.
Matthias
On 5/8/20 11:59 AM, Andreas Neumann wrote:
> Hi Matthias,
> Thank you for listing all the open issues/problem with gpkg that you
> know of. It really helps.
> If we don't like gpkg as default format - the question is: what is the
> alternative?
> a) stay with ESRI shapefile (I think noone would like this)
> b) work with the SQLite, gpkg/OGC community to fix the gpkg issues (my
> preference)
> c) use ESRI FGDB format (then we are at the mercy of ESRI)
> d) invent something new (risky, if only QGIS uses that,
> interoperability would suck)
> I would prefer option b) a lot, and if that is not feasible, then
> maybe d). d) will also be risky.
> a) would equally suck as the current state of gpkg - I've seen far too
> many corrupt shape files, people complaining about interoperability
> issues (ArcGIS would show features that had been deleted in QGIS, )
> and I don't need to repeat the list of the numerous restrictions of
> ESRI shp format.
> Andreas
> Am 08.05.20 um 11:30 schrieb Matthias Kuhn:
>> Hi list,
>> I wondered about the state of GeoPackage. Personally, cince it has
>> been introduced to qgis and evenmore since it has been selected as
>> the default format, I have never grown to fully and completely.
>> I do not want to trigger a evangelical discussion here. I'd like to
>> see where we are and what we can reasonably do to have a default file
>> format which can be recommended with no bad feelings.
>> Here follow a couple of observations over the years, some of them
>> properties of the specs I believe:
>> * The fid requirement
>>   I sometimes want my features to be identified by uuids or others.
>> They also tend to accumulate if derived datasets are created (through
>> processing etc). If I need some pseudo stable primary key there is a
>> rowid builtin into sqlite, we don't need a second one.
>>   Possible mitigation: alter the ogr implementation. possibly alter
>> the standard (required?)
>> * The modification on r/o open
>>   Has caused too much pain on git.
>>   Possible mitigation: a) switch to journal mode=delete (not an easy
>> option because of https://issues.qgis.org/issues/15351) b) only
>> switch to wal mode when layers are put into edit mode (I have strong
>> doubts this is a safe thing to do)
>> * The network share freeze
>>   Our default file should play nicely with (windows) network shares.
>> It's clear to everyone that we can't expect concurrent writes. But it
>> should "just work" for concurrent read by many.
>>   Possible mitigation: switch to journal mode=delete for network
>> shares (we are looking into this)
>> * The wal file appearing next to the file
>>   It is confusing to newcomers and looks almost like a sidecar file.
>> I would care less if it was put into some system cache folder instead
>> of just into my data folder. Or at least if it was a hidden file.
>>   Possible mitigation: switch to journal mode=delete (not an easy
>> * The couple of corrupted files I have received over the years which
>> could only be repaired by a command line "dump contents as sql and
>> execute into new file"
>>   I have not found a way to reproduce this. Some of them were
>> produced by older qgis versions making it easy to violate foreign key
>> constraints and hard to recover. This has been fixed.
>>   Possible mitigation: offer a "repair" option in qgis. Through
>> processing or "on the fly" upon detection.
>> *Default value magic replace values on insert (with no possibility to
>> pre-evaluate them)
>>   E.g. a global sequence like on postgres would be nice. Can be
>> worked around through default values in qgis though.
>>   Possible mitigation: a)add it as a feature to sqlite. b) use qgis
>> default values. c) live with it.
>> *The requirement for a single geometry column per table
>>   I just don't see a good reason to forbid that
>>   Possible mitigation: a) alter the standard. b) ignore the standard
>> and patch the ogr implementation.
>> I wonder how others feel about these topics.
>> - Are there more pain points I forgot to list?
>> - Do you see more approaches to mitigate these problems?
>> - Is someone already working on these issues?
>> It would be great to have a standard file format that we can fully
>> trust. Let's make a reality check if GeoPackage can be this format.
>> Best regards
>> Matthias Kuhn
>> matthias at opengis.ch <mailto:matthias at opengis.ch>
>> +41 (0)76 435 67 63 <tel:+41764356763>
>> OPENGIS.ch Logo <http://www.opengis.ch>
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200508/cbf301bc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200508/cbf301bc/attachment-0001.png>
More information about the QGIS-Developer mailing list
