[QGIS-Developer] icons for temporal controller
Richard Duivenvoorde
rdmailings at duif.net
Mon May 11 23:55:44 PDT 2020
Hi Alexandre,
I agree with your words, but this media-model does not fully map to the
timemanager model OR it kind of does and then the icons fit:
'>|' now IS go to next video/chapter (in anology of a time step to a
song/chapter'.
If you want |< and >| as "go to start or full end",
you only have << and >> as "do one time step", so this does in my view
not fit the 'fast forward/backward' analogy from media.
That is why I think Samweli's proposal to add a pipe-symbol ('|') to the
fastforward to end and start: '<<' and '>>' as a best fitting proposal:
'|<<' and '>>|'.
Regards,
Richard
On 5/11/20 8:54 PM, Alexandre Neto wrote:
> Hi Richard et al.
> I am also used to see the |< and >| as go to start or go to end (next
> video or chapter), I would take << and >> as rewind and fast forwards
> Alexandre Neto
> A segunda, 11/05/2020, 19:21, Richard Duivenvoorde <rdmailings at duif.net
> <mailto:rdmailings at duif.net>> escreveu:
> On 5/8/20 2:41 PM, Samweli wrote:
> > Hi Richard,
> > Yes we definitely need to have commonly used icons in this scenario.
> > The way we thought about this is |< and >| icons would mean
> "rewind one step
> > then pause and play forward one step then pause, respectively".
> > I think the improvement should be on the << and >> icons changed
> to |<< and
> >>> | meaning "rewind to start then pause and skip to end then pause,
> > respectively".
> > Some little explanation
> https://en.wikipedia.org/wiki/Media_control_symbols
> Hi Samweli,
> Sorry for my late reply. So after seeing your wikipedia page it looks
> correct what we have now... So maybe leave it as is.. I have to
> reconnect some wires in my head I think :-)
> I like your refinement though. I think adding the | tot the go to
> start/end would help (me at least)
> Thanks & Regards,
> Richard
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
