[QGIS-Developer] Troubles compiling QGIS master with 3D in Ubuntu 20.04
Andreas Neumann a.neumann at carto.net
Thu May 14 05:00:59 PDT 2020
Hi Saber,
Thanks for the hint. And now that you write about it, I also found the
same hint in the build instructions
(https://github.com/qgis/QGIS/blob/master/INSTALL), section 3.8.1 -
should RTFM ...
Seems to work.
Many thanks,
Andreas
Am 14.05.20 um 13:46 schrieb Saber Razmjooei:
> Hi Andreas,
> Could you try (change /usr/local/src/QGIS_master with your path to
> checked out repo):
> cmake ..
> -DCMAKE_PREFIX_PATH=/usr/local/src/QGIS_master/external/qt3dextra-headers/cmake
> -DQT5_3DEXTRA_INCLUDE_DIR=/usr/local/src/QGIS_master/external/qt3dextra-headers
> -DQT5_3
> DEXTRA_LIBRARY=/usr/lib/x86_64-linux-gnu/libQt53DExtras.so -G Ninja
> -DWITH_3D=TRUE
> Kind regards
> Saber
> On Thu, 14 May 2020 at 12:41, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Hi,
>     After upgrading from Ubuntu 18.04  to 20.04 I have now troubles
>     compiling QGIS with 3D.
>     during "ccmake -GNinja .." I get the following error message:
>     CMake Error at CMakeLists.txt:427 (FIND_PACKAGE):
>         By not providing "FindQt53DExtras.cmake" in CMAKE_MODULE_PATH
>     this
>     project
>         has asked CMake to find a package configuration file provided by
>         "Qt53DExtras", but CMake did not find one.
>         Could not find a package configuration file provided by
>     "Qt53DExtras" with
>         any of the following names:
>           Qt53DExtrasConfig.cmake
>           qt53dextras-config.cmake
>         Add the installation prefix of "Qt53DExtras" to
>     CMAKE_PREFIX_PATH or set
>         "Qt53DExtras_DIR" to a directory containing one of the above
>     files.  If
>         "Qt53DExtras" provides a separate development package or SDK,
>     be sure it
>         has been installed.
>     I checked my packages and the package "libqt53dextras5" is installed,
>     but it doesn't contain the requested file "Qt53DExtrasConfig.cmake".
>     Does someone have an idea what package I might be missing or what
>     config?
>     Thanks,
>     Andreas
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200514/e7587c65/attachment-0001.html>
More information about the QGIS-Developer mailing list
