[QGIS-Developer] annoying frequent github action mail about milestone
Denis Rouzaud denis.rouzaud at gmail.com
Fri May 15 01:28:29 PDT 2020
Although, we do have failing jobs since about 24h
see
https://github.com/qgis/QGIS/actions?query=workflow%3A%22Auto+set+milestone+on+PR%22
I don't get the issue at all, it reports this error:
end of the stream or a document separator is expected at line 2, column 19:
      repository(owner: "qgis", name: "QGIS") {
Nothing has been changed lately and the error is a non-sense to me.
Le ven. 15 mai 2020 à 09:56, Etienne Trimaille <etienne.trimaille at gmail.com>
a écrit :
> Emails are coming your fork Jorge.
> So either disable github action on your fork or I think you might need to
> have this commit in your fork (so in your branch)
> Le ven. 15 mai 2020 à 09:45, Jorge Gustavo Rocha <jgr at di.uminho.pt> a
> écrit :
>> Hi Denis,
>> I'm still receiving these messages.
>> This workflow applies to old PR or just for the ones submitted after
>> your fix?
>> Regards (and thank you for looking into this)
>> Jorge
>> On 11/05/20 10:00, Denis Rouzaud wrote:
>> > let's see https://github.com/qgis/QGIS/pull/36342
>> > Le ven. 8 mai 2020 à 15:00, Sandro Santilli <strk at kbt.io
>> > <mailto:strk at kbt.io>> a écrit :
>> >     On Wed, May 06, 2020 at 12:22:12PM +0200, Werner Macho wrote:
>> >     > Hi!
>> >     > From what I remember you have to disable Actions from the Settings
>> >     of this
>> >     > repository.
>> >     > Topmenu "Settings" -> Left Menu "Actions" - disable actions.
>> >     > Hope this helps
>> >     Thanks, it seems to have helped.
>> >     Could the upstream action be configured NOT to even try to run
>> >     on a fork ?
>> >     --strk;
>> >     _______________________________________________
>> >     QGIS-Developer mailing list
>> >     QGIS-Developer at lists.osgeo.org <mailto:
>> QGIS-Developer at lists.osgeo.org>
>> >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >     Unsubscribe:
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Gabinete 3.29 (Piso 3)
>> Tel: +351 253604480
>> Fax: +351 253604471
>> Móvel: +351 910333888
>> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200515/c1ce3b7b/attachment.html>
More information about the QGIS-Developer mailing list
