[QGIS-Developer] QGIS Server now install a full DE?
Werner Macho
werner.macho at gmail.com
Tue May 19 00:14:00 PDT 2020
Hi !
As far as I can see the solution is in the Link Bas added in his previous
mail.
"To turn this feature off, pass --no-install-recommends to apt or set,
in your apt configuration, APT::Install-Recommends=False."
regards
Werner
On Tue, May 19, 2020 at 9:04 AM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Hi all,
> thanks Bas for the explanation. I believe the default should be no DE -
> how can be the chain of deps be broken?
> Cheers.
> Il 19/05/20 08:47, Sebastiaan Couwenberg ha scritto:
> > On 5/19/20 7:46 AM, Uros Preloznik wrote:
> >> Can anyone explain why was this change necessary?
> > The problem seems to be:
> > qgis-server Depends:
> > python3-qgis Depends:
> > python3-qgis-common Depends:
> > libqgis-customwidgets Depends:
> > qttools5-dev-tools Depends:
> > qt5-assistant Depends:
> > libqt5webkit5 Depends:
> > libqt5positioning5 Recommends:
> > geoclue-2.0 Depends:
> > libnotify4 Recommends:
> > gnome-shell | notification-daemon
> > And via gnome-shell you many more gnome packages installed.
> > The change to install Recommends by default was announced in October
> 2007:
> > https://lists.debian.org/debian-devel-announce/2007/08/msg00000.html
> > This makes sense because the Debian Policy documents Recommends as:
> > The Recommends field should list packages that would be found together
> > with this one in all but unusual installations.
> https://www.debian.org/doc/debian-policy/ch-relationships.html#binary-dependencies-depends-recommends-suggests-enhances-pre-depends
> > Kind Regards,
> > Bas
> Paolo Cavallini
> www.faunalia.eu - QGIS.org
> training, support, development on QGIS, PostGIS and more
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200519/72f071c3/attachment.html>
