[QGIS-Developer] QGIS Server now install a full DE?
Sebastiaan Couwenberg
sebastic at xs4all.nl
Tue May 19 01:51:24 PDT 2020
On 5/19/20 10:45 AM, Sebastiaan Couwenberg wrote:
> On 5/19/20 9:05 AM, Paolo Cavallini wrote:
>> thanks Bas for the explanation. I believe the default should be no DE -
>> how can be the chain of deps be broken?
> Talk to the Ubuntu people.
> In Debian libnotify4 only Recommends notification-daemon.
It looks like Canonical did not want to support notification-daemon, the
version in eoan has this changelog entry:
- generate the notification-daemon recommends with some hacks,
this allows notification-daemon to be demoted to universe
In bionic notification-daemon is the only Recommends as well.
>> Il 19/05/20 08:47, Sebastiaan Couwenberg ha scritto:
>>> On 5/19/20 7:46 AM, Uros Preloznik wrote:
>>>> Can anyone explain why was this change necessary?
>>> The problem seems to be:
>>> qgis-server Depends:
>>> python3-qgis Depends:
>>> python3-qgis-common Depends:
>>> libqgis-customwidgets Depends:
>>> qttools5-dev-tools Depends:
>>> qt5-assistant Depends:
>>> libqt5webkit5 Depends:
>>> libqt5positioning5 Recommends:
>>> geoclue-2.0 Depends:
>>> libnotify4 Recommends:
>>> gnome-shell | notification-daemon
>>> And via gnome-shell you many more gnome packages installed.
>>> The change to install Recommends by default was announced in October 2007:
>>> https://lists.debian.org/debian-devel-announce/2007/08/msg00000.html
>>> This makes sense because the Debian Policy documents Recommends as:
>>> The Recommends field should list packages that would be found together
>>> with this one in all but unusual installations.
>>> https://www.debian.org/doc/debian-policy/ch-relationships.html#binary-dependencies-depends-recommends-suggests-enhances-pre-depends
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
