[QGIS-Developer] Globe Plugin
José de Paula Rodrigues espinafre at gmail.com
Tue May 19 13:03:24 PDT 2020
Hi all,
I've taken a shot at building qgis with the globe plugin enabled on a
current Gentoo. I've found that the plugin must be built against
osgearth no newer than version 2.8 (which was released 2016-09-15),
because newer versions remove features needed by Globe (osgearth 2.9,
released 2018-02-07, removes the osgEarthUtilModule, and osgearth
2.10.1 - which is the latest release, from 2019-04-19, removes Qt
support altogether).
So, I find that the plugin is unbuildable on a modern system, unless
it drops the need for the osgearth library. Should it be kept in the
qgis tree even so?
... et cognoscetis veritatem et veritas liberabit vos.
More information about the QGIS-Developer mailing list
