[QGIS-Developer] QGIS Server now install a full DE?
David Marteau
dmarteau at 3liz.com
Wed May 20 01:32:57 PDT 2020
Qgis server is built on top of the Qgis codebase. Qgis require Qt. Qt
packages come with all the dependencies, needed or not, to run Qt
applications in the large.
The problem is mainly Qt packaging, and there is not much you can do
about this (you may ask why Qgis desktop need gstreamer on linux !)
Le 20/05/2020 à 07:49, Uros Preloznik a écrit :
> Hi,
> Maybe I did open different question with Python support, but I still
> think default setup of QGIS Server should be as light as possible for
> running standard OGC requests. If you have demand for specific tasks
> then you will know what to do to enable Python support and go with
> plugins. It used to be like that before.
> So then we have this issue with installing bunch of unneeded packages.
> I would open issue about that for start.
> best regards
> Uroš
> V V tor., 19. maj 2020 ob 18:35 je oseba Marco Bernasocchi
> <marco at opengis.ch <mailto:marco at opengis.ch>> napisala:
> Hi Uros
> On 19.05.20 11:03, Uros Preloznik wrote:
>> I think main question is does QGIS Server needs dependency to
>> python?
> Unless you want to kill server plugins. Maybe it could be a
> separated qgis-server-python package. but as Bas said, it seems a
> different issue.
> Cheers
> Marco
> Marco Bernasocchi
> OPENGIS.ch CEO
> QGIS.org Chair
> +41 (0)79 467 24 70 <tel:+41794672470>
> OPENGIS.ch Logo <https://www.opengis.ch>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
David Marteau
Responsable Infrastructure
www.3liz.com <http://www.3liz.com>
*Tel*. 06 63 02 89 83
*Bureau*
31, rue de l'Argenterie
34000 Montpellier
*Siège social*
73, allée Kleber
Boulevard de Strasbourg
34000 Montpellier
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200520/9ca159d3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200520/9ca159d3/attachment.png>
