[QGIS-Developer] Unable to build QGIS master due to multiple definitions of sipQgs3DAlgorithms
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Sun Nov 1 00:34:16 PDT 2020
Hi Harrissou,
Here is my working one on Ubuntu 20.04:
-DCMAKE_PREFIX_PATH=~/src/QGIS_master/external/qt3dextra-headers/cmake/Qt53DExtras
-DQT5_3DEXTRA_INCLUDE_DIR=~/src/QGIS_master/external/qt3dextra-headers -D
QT5_3DEXTRA_LIBRARY=/usr/lib/x86_64-linux-gnu/libQt53DExtras.so
-DWITH_3D=True
-DQt53DExtras_DIR=~/src/QGIS_master/external/qt3dextra-headers/cmake/Qt53DExtras
I hope that works for you!
Kind regards
Saber
On Sat, 31 Oct 2020 at 08:34, DelazJ <delazj at gmail.com> wrote:
> Hi all,
> Thanks Peter. I got some time to give it another try. So I trashed my
> build dir and restarted.
> Now I'm stuck at
> *In file included from ../src/3d/qgsskyboxsettings.h:*
> *23, from ../src/3d/qgs3dmapsettings.h:*
> *33, from src/3d/qgis_3d_autogen/**EWIEGA46WW/moc_*
> *qgs3dmapsettings.cpp:9, from src/3d/qgis_3d_autogen/mocs_*
> *compilation.cpp:9:../src/3d/qgsskyboxentity.h:*
> *22:10: fatal error: Qt3DExtras/QCuboidMesh: Aucun fichier ou dossier de
> ce type 22 | #include <Qt3DExtras/QCuboidMesh> |
> ^~~~~~~~~~~~~~~~~~~~~~~~compilation terminated.[52/2925] Building CXX
> object src/3d/CMakeFiles/qgis_3d.dir/**qgsabstractvectorlayer3drender*
> *er.cpp.oninja: build stopped: subcommand failed.*
> I don't know if it has anything to do but I had to fight against the "
> Qt53DExtras" error to enable 3D
> * CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
> (find_package): Could not find a package configuration file provided by
> "Qt53DExtras" with any of the following names:
> Qt53DExtrasConfig.cmake qt53dextras-config.cmake Add the
> installation prefix of "Qt53DExtras" to CMAKE_PREFIX_PATH or set
> "Qt53DExtras_DIR" to a directory containing one of the above files. If
> "Qt53DExtras" provides a separate development package or SDK, be sure it
> has been installed. Call Stack (most recent call first):
> CMakeLists.txt:404 (FIND_PACKAGE)*
> Recipes I found in the list and the install file didn't seem to fix the
> cmake so I set set the QT53DExtras_DIR to
> /pathtoQGISrepo/external/qt3dextra-headers/cmake*/Qt53DExtras* (in which
> I found the missing file)
> Thanks for any suggestion.
> Harrissou
> Le jeu. 29 oct. 2020 à 14:01, Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> a écrit :
>> Hi,
>> can you please remove completely the build folder and start again?
>> Thanks.
>> P/
>> On Thu, Oct 29, 2020 at 1:57 PM DelazJ <delazj at gmail.com> wrote:
>>> Hi devs,
>>> Since yesterday, I'm unable to build QGIS on Ubuntu 20.04 using ninja.
>>> It used to work a couple of days ago.
>>> I'm getting a bunch of errors of the type:
>>> /usr/bin/ld :
>>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart10.cpp.o : dans
>>> la fonction « sipQgs3DAlgorithms::sipProtect_isSignalConnected(QMetaMethod
>>> const&) const » :
>>> /media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart10.cpp:4735 :
>>> définitions multiples de
>>> « sipQgs3DAlgorithms::sipProtect_isSignalConnected(QMetaMethod const&)
>>> const »;
>>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:/media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart8.cpp:892 :
>>> défini pour la première fois ici
>>> /usr/bin/ld :
>>> la fonction
>>> « sipQgs3DAlgorithms::sipProtect_addAlgorithm(QgsProcessingAlgorithm*) » :
>>> /media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart10.cpp:4740 :
>>> « sipQgs3DAlgorithms::sipProtect_addAlgorithm(QgsProcessingAlgorithm*) »;
>>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:/media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart8.cpp:897 :
>>> /usr/bin/ld :
>>> la fonction « sipQgs3DAlgorithms::sipProtectVirt_loadAlgorithms(bool) » :
>>> /media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart10.cpp:4745 :
>>> « sipQgs3DAlgorithms::sipProtectVirt_loadAlgorithms(bool) »;
>>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:/media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart8.cpp:902 :
>>> /usr/bin/ld :
>>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart10.cpp.o:(.data.rel.local+0x2c0) :
>>> définitions multiples de « sipTypeDef__3d_Qgs3DAlgorithms »;
>>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:(.data.rel.local+0x160) :
>>> collect2: error: ld returned 1 exit status
>>> [59/1570] Linking CXX shared library output/lib/libqgis_gui.so.3.17.0
>>> Any hints would be welcome. Thanks
>>> Harrissou
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201101/8043518d/attachment.html>
