[QGIS-Developer] WFS-T, postgis and triggers
Régis Haubourg
regis.haubourg at gmail.com
Sun Nov 1 01:57:16 PDT 2020
+1 with Denis, this is a quite common scenario, but the caching issue,
combined with the good old WFS-T implementation spatialite provider issues
looked like a big challenge.
I think the future transactional version of WFS3 - OGC APIF should speed up
and simplify a lot the protocol part. On my side, I was just waiting fo it
to happen to raise the topic again.
Concerning the client side caching, I'm not up to date with the potential
spatialite provider enhancement.
Having a reliable and efficient way to edit WFS-T would be really nice. But
as Alessandro points out, our application with a lot of database
intelligence will trigger a lot of data refresh in any case and we will
have then some lags.
Best
Régis
Le jeu. 29 oct. 2020 à 15:11, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Le jeu. 29 oct. 2020 à 15:07, Alessandro Pasotti <apasotti at gmail.com> a
> écrit :
>> On Thu, Oct 29, 2020 at 2:59 PM Denis Rouzaud <denis.rouzaud at gmail.com>
>> wrote:
>> > Hi all,
>> > I have a WFS-T layer with a Postgis DB behind it.
>> > On my table, I have an insert trigger (before insert) which sets a
>> field.
>> > When I create a feature on this layer in QGIS, I don't get back the
>> value of this field (I have to refresh the data, by re-opening QGIS for
>> instance).
>> > Is this expected?
>> Yes. The features are locally cached in a SQLite layer and a newly
>> created feature will be stored locally and not retrieve from the
>> server.
>> > Is there anything we can fix?
>> Of course yes but it would require re-fetching the feature(s) after an
>> insert or an update, I think it will slow things down.
> This could be done asynchronously?
> It sounds like a quite common scenario (or not if nobody complained...).
> Thanks for the answer anyway.
>> Besides that there is no perfect solution to server-side changes: if
>> some other user will trigger a data change on the DB we will of course
>> miss it anyway.
>> > Am I doing something wrong?
>> No.
>> Cheers
>> Alessandro Pasotti
>> QCooperative: www.qcooperative.net
>> ItOpen: www.itopen.it
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201101/86d7082c/attachment-0001.html>
