[QGIS-Developer] PyQgis: custom form and enable (trusted) macro
enrico chiaradia enrico.chiaradia at yahoo.it
Thu Nov 12 05:40:11 PST 2020
Dear Devs,
I’m working to a new plugin for qgis 3.10 that use macro to customize
attribute forms behaviour (e.g. openForm, etc…). For security reason,
macros are not enabled by default in QGIS and so, each time you open the
attribute table/form view, it asks to enable macro. That sounds boring
for the final user…
I can manually resolve this modifying the option “enable macros” to “For
this session only” or, by PyQgis, editing the QgsSettings, key
“qgis/enableMacros” to “SessionOnly” and restore old configuration
options after plugin unloads.
The problem is that, during the sessions, all the macros are enabled
showing a security issue. Is there a way to run only trusted macros, for
example stored under my plugin folder?
Many thanks
enrico
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201112/8d1a5e4b/attachment-0001.html>
More information about the QGIS-Developer mailing list
