[QGIS-Developer] QtCreator does not start QGIS?
Sandro Mani
manisandro at gmail.com
Thu Nov 12 09:00:32 PST 2020
Hi Richard
If you are using Qt5.15.{0,1} and are getting random SIGTRAPS, or the
process segfaulting straight after starting through gdb, this might be [1].
Sandro
[1] https://bugreports.qt.io/browse/QTBUG-86319
On 12.11.20 15:45, Richard Duivenvoorde wrote:
> Still having troubles starting QGIS in debug in QtCreator in my setup today.
> See https://duif.net/qc.png
> So QGIS (in QtCreator) starts, and during startup it stops and shows me the dissassembler(?) view. Sometimes I can see something (like in this screendump: something with libnss ?) sometimes all is white/empty.
> Last this I in the log is: "Destroyed while process ("whoami"), which according to git is recently changed but... does not seem related to me:
> https://github.com/qgis/QGIS/commit/7a38388a8762503b0bdba55065fffea2ff24137a
> Regards,
> Richard
> On 11/11/20 9:16 AM, Richard Duivenvoorde wrote:
>> Hi,
>> Currently in my Qt build I cannot debug QGIS in qtcreator because it hangs/stops when showing the splash.
>> After some time the Application Output shows:
>> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [60891ms] [thread:0x5555560d9d00] 2020-11-11T08:58:15 [1] HTTP fetch https://feed.qgis.org/?after=1605081272&lang=en failed with error Operation canceled
>> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] [thread:0x5555560d9d00] 2020-11-11T08:58:15 Network[1] Network request https://feed.qgis.org/?after=1605081272&lang=en timed out
>> I am connected, and https://feed.qgis.org/?after=1605081272&lang=en is available from my browser.
>> Disabling: 'Show QGIS news feed on welcome page' and 'Check QGIS version at startup' fix this.
>> Others have this issue currently?
>> (I hit my head also with this sometimes when in mixed/http proxied environments
>> I still think we should use 'opt in' for these 'QGIS phoning home stuff' instead of 'opt out')
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
