[QGIS-Developer] QtCreator does not start QGIS?
Sandro Mani
manisandro at gmail.com
Thu Nov 12 10:29:45 PST 2020
As for Fedora, F33 and F34 have fixed packages, but I see that the F33
update was never submitted by the maintainer - I've done so now [1].
Best
Sandro
[1] https://bodhi.fedoraproject.org/updates/FEDORA-2020-1893aa323f
On 12.11.20 19:17, Alessandro Pasotti wrote:
> I switched to QT binaries and sources provided by the QT maintenance
> tool and that's my way to Nirvana.
> I self-build PyQt all the others dependencies.
> Cheers
> On Thu, Nov 12, 2020, 18:51 Richard Duivenvoorde <rdmailings at duif.net
> <mailto:rdmailings at duif.net>> wrote:
> Ough, yes, that looks like it (5.15.1)...
> Thanks Sandro for checking.
> The 'random' qtcreator crashes at startup indeed all show
> 'sigtraps'...
> And I also thought that it has something todo with the
> process.start stuff.
> I see QProcess in a lot of places, so I do not think I can disable
> parts of QGIS compile?
> Mmm this is bad (for me & other Testing Debianista's). Hoping
> there will be a fixed version (qt) soon..
> Other options?
> Downgrade Qt?
> Compile Qt myself?
> Install Fedora on another machine (which Qt is there?)?
> Sigh 0o.
> Richard
> On 11/12/20 6:00 PM, Sandro Mani wrote:
> > Hi Richard
> > If you are using Qt5.15.{0,1} and are getting random SIGTRAPS,
> or the process segfaulting straight after starting through gdb,
> this might be [1].
> > Sandro
> > [1] https://bugreports.qt.io/browse/QTBUG-86319
> <https://bugreports.qt.io/browse/QTBUG-86319>
> > On 12.11.20 15:45, Richard Duivenvoorde wrote:
> >> Still having troubles starting QGIS in debug in QtCreator in my
> setup today.
> >> See https://duif.net/qc.png <https://duif.net/qc.png>
> >> So QGIS (in QtCreator) starts, and during startup it stops and
> shows me the dissassembler(?) view. Sometimes I can see something
> (like in this screendump: something with libnss ?) sometimes all
> is white/empty.
> >> Last this I in the log is: "Destroyed while process ("whoami"),
> which according to git is recently changed but... does not seem
> related to me:
> https://github.com/qgis/QGIS/commit/7a38388a8762503b0bdba55065fffea2ff24137a
> <https://github.com/qgis/QGIS/commit/7a38388a8762503b0bdba55065fffea2ff24137a>
> >> Regards,
> >> Richard
> >> On 11/11/20 9:16 AM, Richard Duivenvoorde wrote:
> >>> Hi,
> >>> Currently in my Qt build I cannot debug QGIS in qtcreator
> because it hangs/stops when showing the splash.
> >>> After some time the Application Output shows:
> >>> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [60891ms]
> [thread:0x5555560d9d00] 2020-11-11T08:58:15 [1] HTTP fetch
> https://feed.qgis.org/?after=1605081272&lang=en
> <https://feed.qgis.org/?after=1605081272&lang=en> failed with
> error Operation canceled
> >>> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms]
> [thread:0x5555560d9d00] 2020-11-11T08:58:15 Network[1] Network
> request https://feed.qgis.org/?after=1605081272&lang=en
> <https://feed.qgis.org/?after=1605081272&lang=en> timed out
> >>> I am connected, and
> <https://feed.qgis.org/?after=1605081272&lang=en> is available
> from my browser.
> >>> Disabling: 'Show QGIS news feed on welcome page' and 'Check
> QGIS version at startup' fix this.
> >>> Others have this issue currently?
> >>> (I hit my head also with this sometimes when in mixed/http
> proxied environments
> >>> I still think we should use 'opt in' for these 'QGIS phoning
> home stuff' instead of 'opt out')
> >>> Regards,
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> >>> List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> >>> Unsubscribe:
> >> List info:
> >> Unsubscribe:
> > List info:
> > Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201112/0ceed9f8/attachment-0001.html>
