[QGIS-Developer] QtCreator does not start QGIS?
Richard Duivenvoorde rdmailings at duif.net
Sat Nov 14 07:57:27 PST 2020
For Debian I created an issue:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=974602
Regards,
On 11/12/20 7:29 PM, Sandro Mani wrote:
> As for Fedora, F33 and F34 have fixed packages, but I see that the F33 update was never submitted by the maintainer - I've done so now [1].
> Best
> Sandro
> [1] https://bodhi.fedoraproject.org/updates/FEDORA-2020-1893aa323f
> On 12.11.20 19:17, Alessandro Pasotti wrote:
>> I switched to QT binaries and sources provided by the QT maintenance tool and that's my way to Nirvana.
>> I self-build PyQt all the others dependencies.
>> Cheers
>> On Thu, Nov 12, 2020, 18:51 Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>     Ough, yes, that looks like it (5.15.1)...
>>     Thanks Sandro for checking.
>>     The 'random' qtcreator crashes at startup indeed all show 'sigtraps'...
>>     And I also thought that it has something todo with the process.start stuff.
>>     I see QProcess in a lot of places, so I do not think I can disable parts of QGIS compile?
>>     Mmm this is bad (for me & other Testing Debianista's). Hoping there will be a fixed version (qt) soon..
>>     Other options?
>>     Downgrade Qt?
>>     Compile Qt myself?
>>     Install Fedora on another machine (which Qt is there?)?
>>     Sigh 0o.
>>     Richard
>>     On 11/12/20 6:00 PM, Sandro Mani wrote:
>>     > Hi Richard
>>     > If you are using Qt5.15.{0,1} and are getting random SIGTRAPS, or the process segfaulting straight after starting through gdb, this might be [1].
>>     > Sandro
>>     > [1] https://bugreports.qt.io/browse/QTBUG-86319
>>     > On 12.11.20 15:45, Richard Duivenvoorde wrote:
>>     >> Still having troubles starting QGIS in debug in QtCreator in my setup today.
>>     >> See https://duif.net/qc.png
>>     >> So QGIS (in QtCreator) starts, and during startup it stops and shows me the dissassembler(?) view. Sometimes I can see something (like in this screendump: something with libnss ?) sometimes all is white/empty.
>>     >> Last this I in the log is: "Destroyed while process ("whoami"), which according to git is recently changed but... does not seem related to me:
>>     >> https://github.com/qgis/QGIS/commit/7a38388a8762503b0bdba55065fffea2ff24137a
>>     >> Regards,
>>     >> Richard
>>     >> On 11/11/20 9:16 AM, Richard Duivenvoorde wrote:
>>     >>> Hi,
>>     >>> Currently in my Qt build I cannot debug QGIS in qtcreator because it hangs/stops when showing the splash.
>>     >>> After some time the Application Output shows:
>>     >>> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [60891ms] [thread:0x5555560d9d00] 2020-11-11T08:58:15 [1] HTTP fetch https://feed.qgis.org/?after=1605081272&lang=en failed with error Operation canceled
>>     >>> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] [thread:0x5555560d9d00] 2020-11-11T08:58:15 Network[1] Network request https://feed.qgis.org/?after=1605081272&lang=en timed out
>>     >>> I am connected, and https://feed.qgis.org/?after=1605081272&lang=en is available from my browser.
>>     >>> Disabling: 'Show QGIS news feed on welcome page' and 'Check QGIS version at startup' fix this.
>>     >>> Others have this issue currently?
>>     >>> (I hit my head also with this sometimes when in mixed/http proxied environments
>>     >>> I still think we should use 'opt in' for these 'QGIS phoning home stuff' instead of 'opt out')
>>     >>> Regards,
>>     >>> _______________________________________________
>>     >>> QGIS-Developer mailing list
>>     >>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>>     >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>     >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
