[QGIS-Developer] Library behind native plugin 'Check Geometries'
Nyall Dawson
nyall.dawson at gmail.com
Wed Nov 18 17:44:40 PST 2020
On Wed, 18 Nov 2020 at 20:10, Jakob <jakob at lanstorp.com> wrote:
> What is the rutine or library behind - that the QGIS native plugin Check
> Geometries uses. This plugin finds at lot more topological errors and other
> data inconsistencies than PostGIS st_isvalid() by GEOS and the QGIS menu
> Vector > Geometry Tools > Check Validity (Method QGIS or GEOS).
It's an internal QGIS routine, all located here:
https://github.com/qgis/QGIS/blob/master/src/core/qgsgeometryvalidator.cpp
Hope that helps!
Nyall
> Jakob
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
