[QGIS-Developer] QtCreator does not start QGIS?
Luigi Pirelli luipir at gmail.com
Mon Nov 23 09:41:58 PST 2020
great. thanks for pointing it out... btw I also found that using LLDB
instead of GDB solve too (as workaround). I'll try back to GDB for more
uniformity.
cheers
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Mon, 23 Nov 2020 at 18:30, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Luigi,
> This is an older issue, workaround here:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Qtcreator-debug-issues-tp5389889p5389905.html
> Hope this helps and best wishes
> Matthias
> On Mon, Nov 23, 2020 at 6:26 PM Luigi Pirelli <luipir at gmail.com> wrote:
>> hmmmm... seems the same error happen with qt 5.12.8 (eg.. version with
>> ubuntu 20.04 LTR)
>> src/core/qgsproviderregistry.cpp:261 : (init) [0ms] Checking ogr:
>> ...loaded OK (59 file filters)
>> src/core/auth/qgsauthmanager.cpp:180 : (init) [0ms] Initializing QCA...
>> Thread 5 "QDBusConnection" received signal SIG33, Real-time event 33.
>> [Switching to Thread 0x7fffdaffd700 (LWP 285949)]
>> 0x00007ffff1e4baff in __GI___poll (fds=0x7fffd000eaf0, nfds=5,
>> timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
>> 29 ../sysdeps/unix/sysv/linux/poll.c: No such file or directory.
>> there is a workaround? I need to debug some crashes
>> regards
>> Luigi Pirelli
>> On Thu, 12 Nov 2020 at 18:00, Sandro Mani <manisandro at gmail.com> wrote:
>>> Hi Richard
>>> If you are using Qt5.15.{0,1} and are getting random SIGTRAPS, or the
>>> process segfaulting straight after starting through gdb, this might be
>>> [1].
>>> Sandro
>>> [1] https://bugreports.qt.io/browse/QTBUG-86319
>>> On 12.11.20 15:45, Richard Duivenvoorde wrote:
>>> > Still having troubles starting QGIS in debug in QtCreator in my setup
>>> today.
>>> > See https://duif.net/qc.png
>>> > So QGIS (in QtCreator) starts, and during startup it stops and shows
>>> me the dissassembler(?) view. Sometimes I can see something (like in this
>>> screendump: something with libnss ?) sometimes all is white/empty.
>>> > Last this I in the log is: "Destroyed while process ("whoami"), which
>>> according to git is recently changed but... does not seem related to me:
>>> https://github.com/qgis/QGIS/commit/7a38388a8762503b0bdba55065fffea2ff24137a
>>> > Regards,
>>> > Richard
>>> > On 11/11/20 9:16 AM, Richard Duivenvoorde wrote:
>>> >> Hi,
>>> >> Currently in my Qt build I cannot debug QGIS in qtcreator because it
>>> hangs/stops when showing the splash.
>>> >> After some time the Application Output shows:
>>> >> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [60891ms]
>>> [thread:0x5555560d9d00] 2020-11-11T08:58:15 [1] HTTP fetch
>>> https://feed.qgis.org/?after=1605081272&lang=en failed with error
>>> Operation canceled
>>> >> ../../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms]
>>> [thread:0x5555560d9d00] 2020-11-11T08:58:15 Network[1] Network request
>>> https://feed.qgis.org/?after=1605081272&lang=en timed out
>>> >> I am connected, and https://feed.qgis.org/?after=1605081272&lang=en
>>> is available from my browser.
>>> >> Disabling: 'Show QGIS news feed on welcome page' and 'Check QGIS
>>> version at startup' fix this.
>>> >> Others have this issue currently?
>>> >> (I hit my head also with this sometimes when in mixed/http proxied
>>> environments
>>> >> I still think we should use 'opt in' for these 'QGIS phoning home
>>> stuff' instead of 'opt out')
>>> >> Regards,
>>> >> _______________________________________________
>>> >> QGIS-Developer mailing list
>>> >> QGIS-Developer at lists.osgeo.org
>>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201123/1bafa48c/attachment-0001.html>
More information about the QGIS-Developer mailing list
