[QGIS-Developer] Loading WFS layers from GeoServer
Ian Turton ijturton at gmail.com
Fri Nov 27 01:58:48 PST 2020
On Fri, 27 Nov 2020 at 09:48, Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
wrote:
> Hi,
> I’m trying to load some WFS layers from my internal GeoServer into QGIS
> 3.10 and 3.16. The datastore in GeoServer is based on a view in a SQL
> Server database but it does have a primary key on the spatial table at
> least.
> When I load it in 3.10 it comes in as the image icon (i.e. doesn’t load)
> so I thought I’d try it in the latest version and in that version QGIS just
> disappears (completely crashes).
> Has anyone else had a similar problem and can help me work out how to get
> the layers to load? I suspect the issue is the way the view is configured
> in SQL Server however I also wonder if I need to investigate the 3.16 crash
> and potentially log that as a bug as it is not handling the crash with the
> normal message the application just closes without warning?
Can you check if GeoServer is returning GML or an error message when you
make a WFS request? But I don't think that QGis should crash no matter what
is in the response.
Ian
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201127/14a95bcf/attachment.html>
More information about the QGIS-Developer mailing list
