[QGIS-Developer] QGIS Georeferencer improvements
Martin Dobias
wonder.sk at gmail.com
Thu Oct 8 13:32:22 PDT 2020
Hi Nico
On Fri, Oct 2, 2020 at 1:11 AM Nico Tripcevich <ntripcevich at gmail.com> wrote:
> Hello I saw the discussion of the Georeferencer improvements from April. I
> hope you don't mind if I revive it and chime in in case these improvements
> are under consideration. I posted this as a github issue
> <https://github.com/qgis/QGIS/issues/35051> but maybe it'll get seen here.
> Great there are plans to work on the UI of Georeferencer. I did a lot of
> georeferencing work in Arcmap 10.x years ago and have recently been doing
> quite a bit of work in QGIS3 so I thought based on my experience with both i
> would type up some of the aspects of QGIS Georeferencer I that think could
> be modified for easier flow. Some of these are pretty basic (more basic than
> what is proposed above) but still fall under the Feature Request category.
Thanks for your input... Unfortunately the project we had in mind at
Lutra did not materialize in the end. But maybe someone else would
pick this up and implement some of the proposed georeferencer
improvements!
Regards
Martin
