[QGIS-Developer] GRASS, SAGA processing algs not loading
Tim Sutton
tim at kartoza.com
Fri Oct 9 04:28:22 PDT 2020
Hi
On Thu, Oct 8, 2020 at 11:22 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Thu, 8 Oct 2020 at 22:28, Tim Sutton <tim at kartoza.com> wrote:
> > Hi All
> > So I switched to Fedora 32 on my new desktop instead of Ubuntu and got
> QGIS building easily enough but when I run it there seems to be an issue
> with loading non-QGIS native processing algs (the QGIS native ones load and
> work fine).
> > I have checked the Settings -> Options -> Processing -> Providers and no
> providers are available there.
> Hmm -- this is quite odd. I use Fedora 32 myself and have never had
> issues like this, with no special configuration necessary...
> Did it work before you enabled the GRASS plugin in cmake?
No it hasn't ever worked on this PC since I installed Fedora (from my hand
built binary).
Regards
Tim
> Nyall
> > Question:
> > Does anyone have any suggestions of what else to check to see why the
> GRASS, SAGA (and ultimately I would like to have OTB too) algs are not
> available. Perhaps someone could share their CMakeCache.txt privately with
> me if you have all of these working so that I can compare it to mine?
> > Thanks!
> > Regards
> > Tim
> > Log messages on start up:
> > src/core/qgsmessagelog.cpp:29 : (logMessage) [178ms] 2020-10-06T16:47:57
> Processing[1] Invalid algorithm ID for menu: qgis:distancematrix
> > src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2020-10-06T16:47:57
> Processing[1] Invalid algorithm ID for menu: qgis:listuniquevalues
> Processing[1] Invalid algorithm ID for menu: qgis:basicstatisticsforfields
> Processing[1] Invalid algorithm ID for menu: qgis:randomselection
> qgis:randomselectionwithinsubsets
> Processing[1] Invalid algorithm ID for menu: qgis:randompointsinlayerbounds
> Processing[1] Invalid algorithm ID for menu: qgis:randompointsinsidepolygons
> Processing[1] Invalid algorithm ID for menu: qgis:regularpoints
> Processing[1] Invalid algorithm ID for menu: qgis:eliminateselectedpolygons
> Processing[1] Invalid algorithm ID for menu: qgis:checkvalidity
> Processing[1] Invalid algorithm ID for menu: qgis:exportaddgeometrycolumns
> Processing[1] Invalid algorithm ID for menu: qgis:delaunaytriangulation
> Processing[1] Invalid algorithm ID for menu: qgis:voronoipolygons
> Processing[1] Invalid algorithm ID for menu: qgis:linestopolygons
> Processing[1] Invalid algorithm ID for menu: gdal:warpreproject
> Processing[1] Invalid algorithm ID for menu: gdal:extractprojection
> Processing[1] Invalid algorithm ID for menu: gdal:assignprojection
> Processing[1] Invalid algorithm ID for menu: gdal:rasterize
> Processing[1] Invalid algorithm ID for menu: gdal:polygonize
> Processing[1] Invalid algorithm ID for menu: gdal:translate
> Processing[1] Invalid algorithm ID for menu: gdal:rgbtopct
> Processing[1] Invalid algorithm ID for menu: gdal:pcttorgb
> Processing[1] Invalid algorithm ID for menu: gdal:contour
> Processing[1] Invalid algorithm ID for menu: gdal:cliprasterbyextent
> Processing[1] Invalid algorithm ID for menu: gdal:cliprasterbymasklayer
> Processing[1] Invalid algorithm ID for menu: gdal:sieve
> Processing[1] Invalid algorithm ID for menu: gdal:nearblack
> Processing[1] Invalid algorithm ID for menu: gdal:fillnodata
> Processing[1] Invalid algorithm ID for menu: gdal:proximity
> Processing[1] Invalid algorithm ID for menu: gdal:griddatametrics
> Processing[1] Invalid algorithm ID for menu: gdal:gridaverage
> Processing[1] Invalid algorithm ID for menu: gdal:gridinversedistance
> Processing[1] Invalid algorithm ID for menu: gdal:gridnearestneighbor
> Processing[1] Invalid algorithm ID for menu: gdal:aspect
> Processing[1] Invalid algorithm ID for menu: gdal:hillshade
> Processing[1] Invalid algorithm ID for menu: gdal:roughness
> Processing[1] Invalid algorithm ID for menu: gdal:slope
> gdal:tpitopographicpositionindex
> Processing[1] Invalid algorithm ID for menu: gdal:triterrainruggednessindex
> Processing[1] Invalid algorithm ID for menu: gdal:buildvirtualraster
> Processing[1] Invalid algorithm ID for menu: gdal:merge
> Processing[1] Invalid algorithm ID for menu: gdal:gdalinfo
> Processing[1] Invalid algorithm ID for menu: gdal:overviews
> Processing[1] Invalid algorithm ID for menu: gdal:tileindex
> > src/core/qgsmessagelog.cpp:29 : (logMessage) [33ms] 2020-10-06T16:47:57
> Plugins[0] Loaded Processing (package: processing)
> > src/core/qgsmessagelog.cpp:29 : (logMessage) [30ms] 2020-10-06T16:47:57
> Plugins[0] Loaded DB Manager (package: db_manager)
> > src/core/qgsmessagelog.cpp:29 : (logMessage) [497ms] 2020-10-06T16:47:58
> [0] Application state:
> > QGIS_PREFIX_PATH env var:
> > Prefix:
> > Plugin Path:
> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/lib/qgis/plugins
> > Package Data Path: /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data
> > Active Theme Name: default
> > Active Theme Path:
> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/themes/default/icons/
> > Default Theme Path: :/images/themes/default/
> > Tim Sutton
> > Visit http://kartoza.com to find out about open source:
> > * Desktop GIS programming services
> > * Geospatial web development
> > * GIS Training
> > * Consulting Services
> > Skype: timlinux Irc: timlinux on #qgis at freenode.net
> > Tim is a member of the QGIS Project Steering Committee
> > Kartoza is a merger between Linfiniti and Afrispatial
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201009/092f7a5d/attachment.html>
