[QGIS-Developer] Save as PG dump create obsolete dumps
Paolo Cavallini
cavallini at faunalia.it
Sun Oct 11 23:58:41 PDT 2020
Hi Nyall,
Il 12/10/20 01:15, Nyall Dawson ha scritto:
> On Sat, 10 Oct 2020 at 00:52, Paolo Cavallini <cavallini at faunalia.it> wrote:
>> Hi all,
>> this is what it is produced:
>> SET standard_conforming_strings = OFF;
>> DROP TABLE IF EXISTS "public"."test_export" CASCADE;
>> DELETE FROM geometry_columns WHERE f_table_name = 'test_export' AND
>> f_table_schema = 'public';
>> BEGIN;
>> CREATE TABLE "public"."test_export" ( "ogc_fid" SERIAL, CONSTRAINT
>> "test_export_pk" PRIMARY KEY ("ogc_fid") );
>> SELECT
>> AddGeometryColumn('public','test_export','wkb_geometry',4326,'LINESTRING',2);
> Is this through the standard right click layer - export functionality?
> If so, the SQL is being created by GDAL, not QGIS, so this should be
> raised as a GDAL ticket.
sorry I was unclear:
this is done through the Browaser> Save as file. Is this one also using
GDAL?
Cheers.
Paolo Cavallini
www.faunalia.eu - QGIS.org
training, support, development on QGIS, PostGIS and more
