[QGIS-Developer] Fwd: GPKG and FID -- can we fix this mess?
Nyall Dawson
nyall.dawson at gmail.com
Wed Oct 14 17:45:47 PDT 2020
(forwarding back to list)
---------- Forwarded message ---------
Date: Thu, 15 Oct 2020 at 07:07
Subject: Re: [QGIS-Developer] GPKG and FID -- can we fix this mess?
To: Nyall Dawson <nyall.dawson at gmail.com>
> Greetings,
> Can't we have the full reset option as a failsafe method? This way we work normally and when there is an error related to fids we simply scrap them.
> Personally I don't get fid issues these days and never rely on the fids. I also don't use GML so the other aspects don't affect me.
> Thanks,
> Alex
I think this is a great idea -- we could retain any compliant fid
values without change, but as soon as we hit a duplicate fid or
non-integer fid value then we discard it and generate a new one.
What do you think Even?
Nyall
Le mar. 13 oct. 2020 à 17:45, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> Hi list,
> (Linus Torvalds-style harsh truths incoming, read only after coffee/alcohol!)
> Having spent an incredibly frustrating day fighting with the
> limitations of GPKG and the horrible workflow that they mandate, I'd
> love to start brainstorming on how we can fix this.
> While previous discussions have related to the GPKG sqlite wal mess,
> that has (to the extent of my experience) been resolved in the latest
> release. So I'd like to focus on what I see as the biggest pain point
> of GPKG: the FID column.
> This is a pain point for numerous reasons:
> - The type constraint on the fid column makes it really hard to
> translate datasets with an existing, non-numeric "fid" column into
> geopackage. Eg. GML files often have a textual fid string, and
> attempting to convert these to gpkg results in a string of errors
> about string values not being usable as fid values, and an empty
> result layer. The only workaround here is to translate first to an
> alternative format (such as shp!), delete the fid column, and THEN
> save as gpkg.
> - The fid unique constraint, while understandable, results in a HUGE
> raft of issues while working with these. It's SO easy to get a
> situation where you have duplicate fids in an edit buffer, and no way
> to save these features back to the gpkg. You get a series of 1000s of
> errors about duplicate fid, and then an ambiguous state where you're
> completely unsure exactly what's been saved and what's about to be
> lost. This isn't just attributable to a single tool in QGIS -- it's
> possible to end up with duplicate fids through so many different
> operations, including really simple stuff like copying and pasting
> features!
> I've fought with this since we've really started to push GPKG and,
> frankly, I've given up. I don't think there's any way to fix the
> current situation and leave fids as they currently behave.
> So what I propose is a radical re-think about how GPKG fids are
> handled and exposed by QGIS (and by GDAL).
> I propose that we
> 1. demote fids to being only a "semi-permanent" row identifier, with
> the message being that "sometimes these WILL change and you can't rely
> on them as a permanent id field for joins and row identification". If
> users require a permanent unique identifier (i.e. a primary key) on
> their table then THEY have to make and manage that themselves, just
> like shapefiles etc.
> 2. expose fids as a read-only field. Users can still see them if they
> want, but they cannot edit them.
> 3. make QGIS (or GDAL?) ALWAYS generate a completely new fid whenever
> a row is changed or added. Throwaway the old value, make a new one on
> EVERY edit/addition.
> 4 We COMPLETELY ignore any existing fid value set for features added
> to a GPKG layer. I.e. in the case of translating a GML with a text fid
> field, we completely ignore the incoming GML fid values and instead
> use the "always generate a new fid" rule.
> Yes, these changes will break existing workflows, and possibly break
> existing tools/scripts. But honestly, in my experience and the
> experience of my customers, there's a COMPLETE lack of faith and trust
> in GPKG at this stage. EVERYONE has their horror stories of lost data
> and mangled datasets. We've got to do something drastic, and we've got
> to do it sooner rather than later to salvage what little hope does
> remain for this format.
> Thoughts?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
