[QGIS-Developer] QGIS crash in Settings menu if NOT in english
Richard Duivenvoorde
rdmailings at duif.net
Fri Oct 16 07:44:34 PDT 2020
Hi List,
Can others maybe confirm my crash (I asked Raymond, he can not :-) )... ?
I'm on today's master on Debian Testing.
QGIS version
3.15.0-Master
QGIS code revision
b3066af303
Compiled against Qt
5.14.2
Running against Qt
5.14.2
Compiled against GDAL/OGR
3.1.3
Running against GDAL/OGR
3.1.3
Compiled against GEOS
3.8.1-CAPI-1.13.3
Running against GEOS
3.8.1-CAPI-1.13.3
Compiled against SQLite
3.33.0
Running against SQLite
3.33.0
PostgreSQL Client Version
13.0 (Debian 13.0-3)
SpatiaLite Version
5.0.0
QWT Version
6.1.4
QScintilla2 Version
2.11.5
Compiled against PROJ
7.1.1
Running against PROJ
Rel. 7.1.1, September 1st, 2020
OS Version
Debian GNU/Linux bullseye/sid
This copy of QGIS writes debugging output.
When I start QGIS from command line with another language:
qgis --lang de
(also when I change the language via the settings)
And go to Settings/Options, QGIS crashes
So I'm unable to open the Options dialog... both in a fresh profile and profiles-path
with:
Fatal: ASSERT failure in QgsOptions::checkPageWidgetNameMap(): "QgisApp::optionsPagesMap() is outdated, please update. Missing Advanced", file ../src/app/options/qgsoptions.cpp, line 1272
QGIS died on signal -1[New LWP 289405]
[New LWP 289406]
[New LWP 289407]
[New LWP 289408]
[New LWP 289411]
[New LWP 289412]
[New LWP 289413]
[New LWP 289414]
[New LWP 289415]
[New LWP 289417]
[New LWP 289423]
[New LWP 289427]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007f01c39e72c7 in __GI___wait4 (pid=289516, stat_loc=0x7ffd4c3f88e4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
27 ../sysdeps/unix/sysv/linux/wait4.c: No such file or directory.
[Current thread is 1 (Thread 0x7f01b29e3f80 (LWP 289397))]
#0 0x00007f01c39e72c7 in __GI___wait4 (pid=289516, stat_loc=0x7ffd4c3f88e4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
#1 0x000055e9bd482277 in qgisCrash(int) (signal=-1) at ../src/app/main.cpp:349
status = 32765
pidstr = "--pid=289397\000\000\000\000\220\350t\311\351U\000\000\200\253\255\303\001\177\000"
gdbpid = 289516
exename = "/home/richard/bin/qgis_/master/debug/bin/qgis\000\000\000\"\000\000\000\000\000\000\000\200\253\255\303\001\177\000\000\240\350t\311\351U\000\000\000\001\000\000\000\000\000\000?\000\000\000\000\000\000\000\220\350t\311\351U\000\000@\002\000\000\000\000\000\000\026m\232\303\001\177\000\000$\000\000\000\071\000\000\000n\000\000\000|", '\000' <repeats 11 times>, "\b\000\000\000\000\000\000\000\350\000\000\000\000\000\000\000\240\350t\311\351U\000\000?\000\000\000\000\000\000\000\377\377\377\377\000\000\000\000\377\377\377\377\000\000\000\000\234\313\a\306\001\177\000\000\265\000\000\000\000\000\000\000\000"...
len = 45
#2 0x000055e9bd482850 in myMessageOutput(QtMsgType, QMessageLogContext const&, QString const&) (type=QtFatalMsg, msg=...) at ../src/app/main.cpp:444
#3 0x00007f01c60697d8 in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#4 0x00007f01c60698f9 in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#5 0x00007f01c6037b38 in QMessageLogger::fatal(char const*, ...) const () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#6 0x00007f01c6036ffc in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#7 0x00007f01c92a011f in QgsOptions::checkPageWidgetNameMap() (this=0x55e9c710e650) at ../src/app/options/qgsoptions.cpp:1272
title = {static null = {<No data fields>}, d = 0x55e9c91abc00}
currentPage = 0x55e9c96052d0
item = 0x55e9c95f56d0
idx = 20
pageNames = {d = 0x55e9c974e230}
#8 0x00007f01c929bb81 in QgsOptions::QgsOptions(QWidget*, QFlags<Qt::WindowType>, QList<QgsOptionsWidgetFactory*> const&) (this=0x55e9c710e650, parent=0x55e9c02222c0, fl=..., optionsFactories=...) at ../src/app/options/qgsoptions.cpp:1250
svgPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90f9dd0}, d = 0x55e9c90f9dd0}}, <No data fields>}
red = 255
defSnapUnits = QgsTolerance::Pixels
sysVarsMap = {d = 0x55e9bf2792a0}
localizedPaths = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
authcfg = {static null = {<No data fields>}, d = 0x55e9bfde2e10}
zoomedOutResampling = {static null = {<No data fields>}, d = 0x55e9c0f8cf60}
defaultProjectFileFormat = QgsProject::FileFormat::Qgz
tempLayoutFont = {static staticMetaObject = {d = {superdata = {direct = 0x0}, stringdata = 0x7f01c6abaec0, data = 0x7f01c6abab40, static_metacall = 0x0, relatedMetaObjects = 0x0, extradata = 0x0}}, d = {d = 0x55e9c9129220}, resolve_mask = 1}
joinStyleSetting = QgsGeometry::JoinStyleRound
locatorLayout = 0x55e9c91a85c0
identifyValue = 2
pluginsPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
helpPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf02efe0}, d = 0x55e9bf02efe0}}, <No data fields>}
toleranceType = QgsAbstractGeometry::MaximumAngle
magnifierMin = 10
scalePaths = {static null = {<No data fields>}, d = 0x55e9c0766180}
mode = QgsOptions::NoAction
toleranceTypeIndex = 0
gridStyleString = {static null = {<No data fields>}, d = 0x55e9c0631370}
factories = {<QListSpecialMethods<QgsOptionsWidgetFactory*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c91abca0}, d = 0x55e9c91abca0}}
decimalPlaces = 3
tolerance = 1
templateDir = {d_ptr = {d = 0x55e9c9124f00}}
gridRed = 190
filteredStyles = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90e1fb0}, d = 0x55e9c90e1fb0}}, <No data fields>}
composerTemplatePathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
noProxyUrlPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
areaUnits = QgsUnitTypes::AreaSquareMeters
isQtDefault = true
name = {static null = {<No data fields>}, d = 0x55e9bf639510}
zoomedInResampling = {static null = {<No data fields>}, d = 0x55e9c0f8ced0}
projOpen = 1
layoutFontFamily = {static null = {<No data fields>}, d = 0x55e9bfb739e0}
addedLocales = {q_hash = {{d = 0x55e9c737b390, e = 0x55e9c737b390}}}
schemeMenu = 0x55e9c9127290
allLocales = {<QListSpecialMethods<QLocale>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c91854a0}, d = 0x55e9c91854a0}}
myLayerDefaultCrs = {static null = {<No data fields>}, d = 0x55e9bf62b9e0}
highlightAlpha = 128
cacheSize = 52428800
ok = true
unit = QgsUnitTypes::AngleDegrees
theme = {static null = {<No data fields>}, d = 0x55e9bf26db10}
defRadiusUnits = QgsTolerance::Pixels
highlightColor = {cspec = QColor::Rgb, ct = {argb = {alpha = 32896, red = 65535, green = 0, blue = 0, pad = 0}, ahsv = {alpha = 32896, hue = 65535, saturation = 0, value = 0, pad = 0}, acmyk = {alpha = 32896, cyan = 65535, magenta = 0, yellow = 0, black = 0}, ahsl = {alpha = 32896, hue = 65535, saturation = 0, lightness = 0, pad = 0}, argbExtended = {alphaF16 = 32896, redF16 = 65535, greenF16 = 0, blueF16 = 0, pad = 0}, array = {32896, 65535, 0, 0, 0}}}
hiddenPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
projectCrsBehavior = QgsGui::UseCrsOfFirstLayerAdded
baseUnit = true
pyMacroMode = Qgis::Ask
advancedFactory = {<QgsOptionsWidgetFactory> = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c84842c0 <qt_meta_stringdata_QgsOptionsWidgetFactory>, data = 0x7f01c8484300 <qt_meta_data_QgsOptionsWidgetFactory>, static_metacall = 0x7f01c78a95b8 <QgsOptionsWidgetFactory::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mTitle = {static null = {<No data fields>}, d = 0x55e9c91abc00}, mIcon = {d = 0x0}}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c8a4af40 <QgsOptionsWidgetFactory::staticMetaObject>}, stringdata = 0x7f01c95467c0 <qt_meta_stringdata_QgsAdvancedSettingsOptionsFactory>, data = 0x7f01c9546800 <qt_meta_data_QgsAdvancedSettingsOptionsFactory>, static_metacall = 0x7f01c8dbbfc4 <QgsAdvancedSettingsOptionsFactory::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}}
fmCustomVar = {d = {d = 0x55e9bf2e2da0}}
currentVarsList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90eff20}, d = 0x55e9c90eff20}}, <No data fields>}
green = 0
gridGreen = 190
gridBlue = 190
language18nList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c912b7d0}, d = 0x55e9c912b7d0}}, <No data fields>}
localeOverrideFlag = true
fontFamily = {static null = {<No data fields>}, d = 0x55e9bf2de7f0}
alpha = 30
gridAlpha = 100
userLocale = {static null = {<No data fields>}, d = 0x55e9c055e8e0}
blue = 0
gridColor = {cspec = QColor::Rgb, ct = {argb = {alpha = 25700, red = 48830, green = 48830, blue = 48830, pad = 0}, ahsv = {alpha = 25700, hue = 48830, saturation = 48830, value = 48830, pad = 0}, acmyk = {alpha = 25700, cyan = 48830, magenta = 48830, yellow = 48830, black = 0}, ahsl = {alpha = 25700, hue = 48830, saturation = 48830, lightness = 48830, pad = 0}, argbExtended = {alphaF16 = 25700, redF16 = 48830, greenF16 = 48830, blueF16 = 48830, pad = 0}, array = {25700, 48830, 48830, 48830, 0}}}
highlightBuffer = 0.5
useCustomVars = false
customVarsList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
magnifierVal = 100
templateDirName = {static null = {<No data fields>}, d = 0x55e9bf56a1e0}
settingProxyType = {static null = {<No data fields>}, d = 0x55e9bfcae6c0}
context = {d = {d = 0x55e9c73bd3b0}}
currentLocale = {static null = {<No data fields>}, d = 0x55e9c8f103e0}
fmCustomVarH = 24
defaultProjectCrs = {static null = {<No data fields>}, d = 0x55e9c0a21a20}
distanceUnits = QgsUnitTypes::DistanceMeters
globalLocale = {static null = {<No data fields>}, d = 0x55e9c055e170}
defaultSnapMode = {i = 1}
styles = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90e1fb0}, d = 0x55e9c90e1fb0}}, <No data fields>}
themes = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90e2010}, d = 0x55e9c90e2010}}, <No data fields>}
magnifierMax = 1600
customSchemes = {<QListSpecialMethods<QgsCustomColorScheme*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c91286c0}, d = 0x55e9c91286c0}}
markerStyle = {static null = {<No data fields>}, d = 0x55e9bf40d0d0}
highlightMinWidth = 1
index = 1
myScalesList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c910e2e0}, d = 0x55e9c910e2e0}}, <No data fields>}
showGroupSeparator = false
#9 0x00007f01c8e69cd3 in QgisApp::createOptionsDialog(QWidget*) (this=0x55e9c02222c0, parent=0x55e9c02222c0) at ../src/app/qgisapp.cpp:12322
factories = {<QListSpecialMethods<QgsOptionsWidgetFactory*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c6e88ed0}, d = 0x55e9c6e88ed0}}
constMOptionsWidgetFactories = {<QListSpecialMethods<QPointer<QgsOptionsWidgetFactory> >> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c487afd0}, d = 0x55e9c487afd0}}
#10 0x00007f01c8e69e5c in QgisApp::showOptionsDialog(QWidget*, QString const&, int) (this=0x55e9c02222c0, parent=0x55e9c02222c0, currentPage=..., pageNumber=-1) at ../src/app/qgisapp.cpp:12328
optionsDialog = std::unique_ptr<class QgsOptions> = {get() = 0x0}
mySettings = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c528e460 <qt_meta_stringdata_QgsSettings>, data = 0x7f01c528e4a0 <qt_meta_data_QgsSettings>, static_metacall = 0x7f01c431e974 <QgsSettings::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mUserSettings = 0x0, mGlobalSettings = 0x0, mUsingGlobalArray = false}
oldScales = {static null = {<No data fields>}, d = 0x800000000000000e}
#11 0x00007f01c8e68188 in QgisApp::options() (this=0x55e9c02222c0) at ../src/app/qgisapp.cpp:12194
#12 0x00007f01c8f0df9b in QtPrivate::FunctorCall<QtPrivate::IndexesList<>, QtPrivate::List<>, void, void (QgisApp::*)()>::call(void (QgisApp::*)(), QgisApp*, void**) (f=(void (QgisApp::*)(class QgisApp * const)) 0x7f01c8e68156 <QgisApp::options()>, o=0x55e9c02222c0, arg=0x7ffd4c3fd0a0) at /usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:152
#13 0x00007f01c8f06fc5 in QtPrivate::FunctionPointer<void (QgisApp::*)()>::call<QtPrivate::List<>, void>(void (QgisApp::*)(), QgisApp*, void**) (f=(void (QgisApp::*)(class QgisApp * const)) 0x7f01c8e68156 <QgisApp::options()>, o=0x55e9c02222c0, arg=0x7ffd4c3fd0a0) at /usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:185
#14 0x00007f01c8ef93d0 in QtPrivate::QSlotObject<void (QgisApp::*)(), QtPrivate::List<>, void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) (which=1, this_=0x55e9c0701e10, r=0x55e9c02222c0, a=0x7ffd4c3fd0a0, ret=0x0) at /usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:418
#15 0x00007f01c627f8c6 in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#16 0x00007f01c6cdeac2 in QAction::triggered(bool) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#17 0x00007f01c6ce1301 in QAction::activate(QAction::ActionEvent) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#18 0x00007f01c6e5a01a in () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#19 0x00007f01c6e61542 in () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#20 0x00007f01c6d2552e in QWidget::event(QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#21 0x00007f01c6ce503f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#22 0x00007f01c6cea781 in QApplication::notify(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#23 0x00007f01c48a2c59 in QgsApplication::notify(QObject*, QEvent*) (this=0x7ffd4c3fe840, receiver=0x55e9bfb50cd0, event=0x7ffd4c3fd840) at ../src/core/qgsapplication.cpp:456
done = true
__PRETTY_FUNCTION__ = "virtual bool QgsApplication::notify(QObject*, QEvent*)"
#24 0x00007f01c624ab62 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#25 0x00007f01c6ce9696 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#26 0x00007f01c6d3e36f in () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#27 0x00007f01c6d407ae in () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#28 0x00007f01c6ce503f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#29 0x00007f01c48a2c59 in QgsApplication::notify(QObject*, QEvent*) (this=0x7ffd4c3fe840, receiver=0x55e9c6e885a0, event=0x7ffd4c3fdc30) at ../src/core/qgsapplication.cpp:456
done = true
#30 0x00007f01c624ab62 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#31 0x00007f01c661245b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#32 0x00007f01c65e8c0b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#33 0x00007f0176de6b6a in () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#34 0x00007f01bc067bab in g_main_context_dispatch () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#35 0x00007f01bc067e58 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#36 0x00007f01bc067f0f in g_main_context_iteration () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#37 0x00007f01c62a02ff in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#38 0x00007f01c62494db in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#39 0x00007f01c6251782 in QCoreApplication::exec() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#40 0x000055e9bd489af2 in main(int, char**) (argc=3, argv=0x7ffd4c3ffbd8) at ../src/app/main.cpp:1637
preApplicationLogMessages = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf02f070}, d = 0x55e9bf02f070}}, <No data fields>}
__FUNCTION__ = "main"
mySnapshotFileName = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
configLocalStorageLocation = {static null = {<No data fields>}, d = 0x55e9bf1fc270}
profileName = {static null = {<No data fields>}, d = 0x55e9bf2032b0}
mySnapshotWidth = 800
mySnapshotHeight = 600
myHideSplash = false
settingsMigrationForce = false
mySkipVersionCheck = false
hideBrowser = false
myRestoreDefaultWindowState = false
myRestorePlugins = true
myCustomization = true
dxfOutputFile = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
dxfSymbologyMode = QgsDxfExport::SymbolLayerSymbology
dxfScale = 50000
dxfEncoding = {static null = {<No data fields>}, d = 0x55e9bd494b00 <main::{lambda()#2}::operator()() const::qstring_literal>}
dxfMapTheme = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
dxfExtent = {mXmin = 0, mYmin = 0, mXmax = 0, mYmax = 0}
takeScreenShots = false
screenShotsPath = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
screenShotsCategories = 0
myInitialExtent = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
translationCode = {static null = {<No data fields>}, d = 0x55e9bf1fa980}
authdbdirectory = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
pythonfile = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
customizationfile = {static null = {<No data fields>}, d = 0x55e9bf6aea90}
globalsettingsfile = {static null = {<No data fields>}, d = 0x55e9bf1fb220}
openClProgramFolder = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
args = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf1fa1a0}, d = 0x55e9bf1fa1a0}}, <No data fields>}
myUseGuiFlag = true
rootProfileFolder = {static null = {<No data fields>}, d = 0x55e9bf1fc140}
manager = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c5292820 <qt_meta_stringdata_QgsUserProfileManager>, data = 0x7f01c52928a0 <qt_meta_data_QgsUserProfileManager>, static_metacall = 0x7f01c4322b60 <QgsUserProfileManager::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mWatchProfiles = false, mWatcher = std::unique_ptr<class QFileSystemWatcher> = {get() = 0x0}, mRootProfilePath = {static null = {<No data fields>}, d = 0x55e9bf1fc140}, mUserProfile = std::unique_ptr<class QgsUserProfile> = {get() = 0x0}, mSettings = std::unique_ptr<class QSettings> = {get() = 0x55e9bf1fa080}}
profile = 0x55e9bf1fc4d0
profileFolder = {static null = {<No data fields>}, d = 0x55e9bf1f7d10}
myApp = {<QApplication> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c71d9160 <QApplication::staticMetaObject>}, stringdata = 0x7f01c527f0a0 <qt_meta_stringdata_QgsApplication>, data = 0x7f01c527f2a0 <qt_meta_data_QgsApplication>, static_metacall = 0x7f01c4308bd6 <QgsApplication::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, static QGIS_ORGANIZATION_NAME = 0x7f01c53c55da "QGIS", static QGIS_ORGANIZATION_DOMAIN = 0x7f01c53c55df "qgis.org", static QGIS_APPLICATION_NAME = 0x7f01c53c55e8 "QGIS3", static mFileOpenEventReceiver31500 = 0x55e9c02222c0, static mInitialized31500 = true, static mRunningFromBuildDir31500 = false, static sMaxThreads31500 = -1, mIconCache = {d = 0x55e9bf3ce2d0}, mCursorCache = {d = 0x55e9c0536b70}, mQgisTranslator = 0x55e9bf3d8f80, mQtTranslator = 0x55e9bf3d0fc0, mDataItemProviderRegistry = 0x55e9bfb4e290, mAuthManager = 0x55e9bfe65cc0, mApplicationMembers = 0x55e9bf3b7040, static sApplicationMembers = 0x0, static sAuthManager = 0x0}
settings = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c528e460 <qt_meta_stringdata_QgsSettings>, data = 0x7f01c528e4a0 <qt_meta_data_QgsSettings>, static_metacall = 0x7f01c431e974 <QgsSettings::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mUserSettings = 0x55e9bf28b800, mGlobalSettings = 0x55e9bf228bc0, mUsingGlobalArray = false}
libPaths = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf91ddb0}, d = 0x55e9bf91ddb0}}, <No data fields>}
relLibPath = {static null = {<No data fields>}, d = 0x55e9bf695c40}
customizationsettings = 0x55e9bf91d4f0
systemEnvVars = {d = 0x55e9bf2792a0}
desiredStyle = {static null = {<No data fields>}, d = 0x55e9bf639510}
activeStyleName = {static null = {<No data fields>}, d = 0x55e9bfe78da0}
mySplashPath = {static null = {<No data fields>}, d = 0x7f01c53c66c0 <QgsApplication::splashPath()::{lambda()#1}::operator()() const::qstring_literal>}
myPixmap = <incomplete type>
w = 600
h = 300
mypSplash = 0x55e9bfee4270
qgis = 0x55e9c02222c0
sigwatch = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x55e9bd4d63c0 <qt_meta_stringdata_UnixSignalWatcher>, data = 0x55e9bd4d6480 <qt_meta_data_UnixSignalWatcher>, static_metacall = 0x55e9bd490ebe <UnixSignalWatcher::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, d_ptr = 0x55e9bfb3c190}
retval = -1119002368
[Inferior 1 (process 289397) detached]
