[QGIS-Developer] QGIS crash in Settings menu if NOT in english
Andreas Neumann a.neumann at carto.net
Fri Oct 16 07:57:52 PDT 2020
Yes - I have the same crash - I thought that I messed up my
self-compiled version - but apparently not.
Whenever I switch to German, and then open the Settings menu: --> crash.
For switching back to English, I have to do it in an older version that
doesn't crash.
Thanks for reporting this issue!
Andreas
On 2020-10-16 16:44, Richard Duivenvoorde wrote:
> Hi List,
> Can others maybe confirm my crash (I asked Raymond, he can not :-) )... ?
> I'm on today's master on Debian Testing.
> QGIS version
> 3.15.0-Master
> QGIS code revision
> b3066af303
> Compiled against Qt
> 5.14.2
> Running against Qt
> 5.14.2
> Compiled against GDAL/OGR
> 3.1.3
> Running against GDAL/OGR
> 3.1.3
> Compiled against GEOS
> 3.8.1-CAPI-1.13.3
> Running against GEOS
> 3.8.1-CAPI-1.13.3
> Compiled against SQLite
> 3.33.0
> Running against SQLite
> 3.33.0
> PostgreSQL Client Version
> 13.0 (Debian 13.0-3)
> SpatiaLite Version
> 5.0.0
> QWT Version
> 6.1.4
> QScintilla2 Version
> 2.11.5
> Compiled against PROJ
> 7.1.1
> Running against PROJ
> Rel. 7.1.1, September 1st, 2020
> OS Version
> Debian GNU/Linux bullseye/sid
> This copy of QGIS writes debugging output.
> When I start QGIS from command line with another language:
> qgis --lang de
> (also when I change the language via the settings)
> And go to Settings/Options, QGIS crashes
> So I'm unable to open the Options dialog... both in a fresh profile and profiles-path
> with:
> Fatal: ASSERT failure in QgsOptions::checkPageWidgetNameMap(): "QgisApp::optionsPagesMap() is outdated, please update. Missing Advanced", file ../src/app/options/qgsoptions.cpp, line 1272
> QGIS died on signal -1[New LWP 289405]
> [New LWP 289406]
> [New LWP 289407]
> [New LWP 289408]
> [New LWP 289411]
> [New LWP 289412]
> [New LWP 289413]
> [New LWP 289414]
> [New LWP 289415]
> [New LWP 289417]
> [New LWP 289423]
> [New LWP 289427]
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> 0x00007f01c39e72c7 in __GI___wait4 (pid=289516, stat_loc=0x7ffd4c3f88e4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
> 27    ../sysdeps/unix/sysv/linux/wait4.c: No such file or directory.
> [Current thread is 1 (Thread 0x7f01b29e3f80 (LWP 289397))]
> #0  0x00007f01c39e72c7 in __GI___wait4 (pid=289516, stat_loc=0x7ffd4c3f88e4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
> #1  0x000055e9bd482277 in qgisCrash(int) (signal=-1) at ../src/app/main.cpp:349
> status = 32765
> pidstr = "--pid=289397\000\000\000\000\220\350t\311\351U\000\000\200\253\255\303\001\177\000"
> gdbpid = 289516
> exename = "/home/richard/bin/qgis_/master/debug/bin/qgis\000\000\000\"\000\000\000\000\000\000\000\200\253\255\303\001\177\000\000\240\350t\311\351U\000\000\000\001\000\000\000\000\000\000?\000\000\000\000\000\000\000\220\350t\311\351U\000\000@\002\000\000\000\000\000\000\026m\232\303\001\177\000\000$\000\000\000\071\000\000\000n\000\000\000|", '\000' <repeats 11 times>, "\b\000\000\000\000\000\000\000\350\000\000\000\000\000\000\000\240\350t\311\351U\000\000?\000\000\000\000\000\000\000\377\377\377\377\000\000\000\000\377\377\377\377\000\000\000\000\234\313\a\306\001\177\000\000\265\000\000\000\000\000\000\000\000"...
> len = 45
> #2  0x000055e9bd482850 in myMessageOutput(QtMsgType, QMessageLogContext const&, QString const&) (type=QtFatalMsg, msg=...) at ../src/app/main.cpp:444
> #3  0x00007f01c60697d8 in  () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #4  0x00007f01c60698f9 in  () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #5  0x00007f01c6037b38 in QMessageLogger::fatal(char const*, ...) const () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #6  0x00007f01c6036ffc in  () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #7  0x00007f01c92a011f in QgsOptions::checkPageWidgetNameMap() (this=0x55e9c710e650) at ../src/app/options/qgsoptions.cpp:1272
> title = {static null = {<No data fields>}, d = 0x55e9c91abc00}
> currentPage = 0x55e9c96052d0
> item = 0x55e9c95f56d0
> idx = 20
> pageNames = {d = 0x55e9c974e230}
> #8  0x00007f01c929bb81 in QgsOptions::QgsOptions(QWidget*, QFlags<Qt::WindowType>, QList<QgsOptionsWidgetFactory*> const&) (this=0x55e9c710e650, parent=0x55e9c02222c0, fl=..., optionsFactories=...) at ../src/app/options/qgsoptions.cpp:1250
> svgPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90f9dd0}, d = 0x55e9c90f9dd0}}, <No data fields>}
> red = 255
> defSnapUnits = QgsTolerance::Pixels
> sysVarsMap = {d = 0x55e9bf2792a0}
> localizedPaths = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
> authcfg = {static null = {<No data fields>}, d = 0x55e9bfde2e10}
> zoomedOutResampling = {static null = {<No data fields>}, d = 0x55e9c0f8cf60}
> defaultProjectFileFormat = QgsProject::FileFormat::Qgz
> tempLayoutFont = {static staticMetaObject = {d = {superdata = {direct = 0x0}, stringdata = 0x7f01c6abaec0, data = 0x7f01c6abab40, static_metacall = 0x0, relatedMetaObjects = 0x0, extradata = 0x0}}, d = {d = 0x55e9c9129220}, resolve_mask = 1}
> joinStyleSetting = QgsGeometry::JoinStyleRound
> locatorLayout = 0x55e9c91a85c0
> identifyValue = 2
> pluginsPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
> helpPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf02efe0}, d = 0x55e9bf02efe0}}, <No data fields>}
> toleranceType = QgsAbstractGeometry::MaximumAngle
> magnifierMin = 10
> scalePaths = {static null = {<No data fields>}, d = 0x55e9c0766180}
> mode = QgsOptions::NoAction
> toleranceTypeIndex = 0
> gridStyleString = {static null = {<No data fields>}, d = 0x55e9c0631370}
> factories = {<QListSpecialMethods<QgsOptionsWidgetFactory*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c91abca0}, d = 0x55e9c91abca0}}
> decimalPlaces = 3
> tolerance = 1
> templateDir = {d_ptr = {d = 0x55e9c9124f00}}
> gridRed = 190
> filteredStyles = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90e1fb0}, d = 0x55e9c90e1fb0}}, <No data fields>}
> composerTemplatePathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
> noProxyUrlPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
> areaUnits = QgsUnitTypes::AreaSquareMeters
> isQtDefault = true
> name = {static null = {<No data fields>}, d = 0x55e9bf639510}
> zoomedInResampling = {static null = {<No data fields>}, d = 0x55e9c0f8ced0}
> projOpen = 1
> layoutFontFamily = {static null = {<No data fields>}, d = 0x55e9bfb739e0}
> addedLocales = {q_hash = {{d = 0x55e9c737b390, e = 0x55e9c737b390}}}
> schemeMenu = 0x55e9c9127290
> allLocales = {<QListSpecialMethods<QLocale>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c91854a0}, d = 0x55e9c91854a0}}
> myLayerDefaultCrs = {static null = {<No data fields>}, d = 0x55e9bf62b9e0}
> highlightAlpha = 128
> cacheSize = 52428800
> ok = true
> unit = QgsUnitTypes::AngleDegrees
> theme = {static null = {<No data fields>}, d = 0x55e9bf26db10}
> defRadiusUnits = QgsTolerance::Pixels
> highlightColor = {cspec = QColor::Rgb, ct = {argb = {alpha = 32896, red = 65535, green = 0, blue = 0, pad = 0}, ahsv = {alpha = 32896, hue = 65535, saturation = 0, value = 0, pad = 0}, acmyk = {alpha = 32896, cyan = 65535, magenta = 0, yellow = 0, black = 0}, ahsl = {alpha = 32896, hue = 65535, saturation = 0, lightness = 0, pad = 0}, argbExtended = {alphaF16 = 32896, redF16 = 65535, greenF16 = 0, blueF16 = 0, pad = 0}, array = {32896, 65535, 0, 0, 0}}}
> hiddenPathList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
> projectCrsBehavior = QgsGui::UseCrsOfFirstLayerAdded
> baseUnit = true
> pyMacroMode = Qgis::Ask
> advancedFactory = {<QgsOptionsWidgetFactory> = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c84842c0 <qt_meta_stringdata_QgsOptionsWidgetFactory>, data = 0x7f01c8484300 <qt_meta_data_QgsOptionsWidgetFactory>, static_metacall = 0x7f01c78a95b8 <QgsOptionsWidgetFactory::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mTitle = {static null = {<No data fields>}, d = 0x55e9c91abc00}, mIcon = {d = 0x0}}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c8a4af40 <QgsOptionsWidgetFactory::staticMetaObject>}, stringdata = 0x7f01c95467c0 <qt_meta_stringdata_QgsAdvancedSettingsOptionsFactory>, data = 0x7f01c9546800 <qt_meta_data_QgsAdvancedSettingsOptionsFactory>, static_metacall = 0x7f01c8dbbfc4 <QgsAdvancedSettingsOptionsFactory::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0,
extradata = 0x0}}}
> fmCustomVar = {d = {d = 0x55e9bf2e2da0}}
> currentVarsList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90eff20}, d = 0x55e9c90eff20}}, <No data fields>}
> green = 0
> gridGreen = 190
> gridBlue = 190
> language18nList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c912b7d0}, d = 0x55e9c912b7d0}}, <No data fields>}
> localeOverrideFlag = true
> fontFamily = {static null = {<No data fields>}, d = 0x55e9bf2de7f0}
> alpha = 30
> gridAlpha = 100
> userLocale = {static null = {<No data fields>}, d = 0x55e9c055e8e0}
> blue = 0
> gridColor = {cspec = QColor::Rgb, ct = {argb = {alpha = 25700, red = 48830, green = 48830, blue = 48830, pad = 0}, ahsv = {alpha = 25700, hue = 48830, saturation = 48830, value = 48830, pad = 0}, acmyk = {alpha = 25700, cyan = 48830, magenta = 48830, yellow = 48830, black = 0}, ahsl = {alpha = 25700, hue = 48830, saturation = 48830, lightness = 48830, pad = 0}, argbExtended = {alphaF16 = 25700, redF16 = 48830, greenF16 = 48830, blueF16 = 48830, pad = 0}, array = {25700, 48830, 48830, 48830, 0}}}
> highlightBuffer = 0.5
> useCustomVars = false
> customVarsList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7f01c632c3b0 <QListData::shared_null>}, d = 0x7f01c632c3b0 <QListData::shared_null>}}, <No data fields>}
> magnifierVal = 100
> templateDirName = {static null = {<No data fields>}, d = 0x55e9bf56a1e0}
> settingProxyType = {static null = {<No data fields>}, d = 0x55e9bfcae6c0}
> context = {d = {d = 0x55e9c73bd3b0}}
> currentLocale = {static null = {<No data fields>}, d = 0x55e9c8f103e0}
> fmCustomVarH = 24
> defaultProjectCrs = {static null = {<No data fields>}, d = 0x55e9c0a21a20}
> distanceUnits = QgsUnitTypes::DistanceMeters
> globalLocale = {static null = {<No data fields>}, d = 0x55e9c055e170}
> defaultSnapMode = {i = 1}
> styles = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90e1fb0}, d = 0x55e9c90e1fb0}}, <No data fields>}
> themes = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c90e2010}, d = 0x55e9c90e2010}}, <No data fields>}
> magnifierMax = 1600
> customSchemes = {<QListSpecialMethods<QgsCustomColorScheme*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c91286c0}, d = 0x55e9c91286c0}}
> markerStyle = {static null = {<No data fields>}, d = 0x55e9bf40d0d0}
> highlightMinWidth = 1
> index = 1
> myScalesList = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c910e2e0}, d = 0x55e9c910e2e0}}, <No data fields>}
> showGroupSeparator = false
> #9  0x00007f01c8e69cd3 in QgisApp::createOptionsDialog(QWidget*) (this=0x55e9c02222c0, parent=0x55e9c02222c0) at ../src/app/qgisapp.cpp:12322
> factories = {<QListSpecialMethods<QgsOptionsWidgetFactory*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c6e88ed0}, d = 0x55e9c6e88ed0}}
> constMOptionsWidgetFactories = {<QListSpecialMethods<QPointer<QgsOptionsWidgetFactory> >> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9c487afd0}, d = 0x55e9c487afd0}}
> #10 0x00007f01c8e69e5c in QgisApp::showOptionsDialog(QWidget*, QString const&, int) (this=0x55e9c02222c0, parent=0x55e9c02222c0, currentPage=..., pageNumber=-1) at ../src/app/qgisapp.cpp:12328
> optionsDialog = std::unique_ptr<class QgsOptions> = {get() = 0x0}
> mySettings = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c528e460 <qt_meta_stringdata_QgsSettings>, data = 0x7f01c528e4a0 <qt_meta_data_QgsSettings>, static_metacall = 0x7f01c431e974 <QgsSettings::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mUserSettings = 0x0, mGlobalSettings = 0x0, mUsingGlobalArray = false}
> oldScales = {static null = {<No data fields>}, d = 0x800000000000000e}
> #11 0x00007f01c8e68188 in QgisApp::options() (this=0x55e9c02222c0) at ../src/app/qgisapp.cpp:12194
> #12 0x00007f01c8f0df9b in QtPrivate::FunctorCall<QtPrivate::IndexesList<>, QtPrivate::List<>, void, void (QgisApp::*)()>::call(void (QgisApp::*)(), QgisApp*, void**) (f=(void (QgisApp::*)(class QgisApp * const)) 0x7f01c8e68156 <QgisApp::options()>, o=0x55e9c02222c0, arg=0x7ffd4c3fd0a0) at /usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:152
> #13 0x00007f01c8f06fc5 in QtPrivate::FunctionPointer<void (QgisApp::*)()>::call<QtPrivate::List<>, void>(void (QgisApp::*)(), QgisApp*, void**) (f=(void (QgisApp::*)(class QgisApp * const)) 0x7f01c8e68156 <QgisApp::options()>, o=0x55e9c02222c0, arg=0x7ffd4c3fd0a0) at /usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:185
> #14 0x00007f01c8ef93d0 in QtPrivate::QSlotObject<void (QgisApp::*)(), QtPrivate::List<>, void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) (which=1, this_=0x55e9c0701e10, r=0x55e9c02222c0, a=0x7ffd4c3fd0a0, ret=0x0) at /usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:418
> #15 0x00007f01c627f8c6 in  () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #16 0x00007f01c6cdeac2 in QAction::triggered(bool) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #17 0x00007f01c6ce1301 in QAction::activate(QAction::ActionEvent) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #18 0x00007f01c6e5a01a in  () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #19 0x00007f01c6e61542 in  () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #20 0x00007f01c6d2552e in QWidget::event(QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #21 0x00007f01c6ce503f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #22 0x00007f01c6cea781 in QApplication::notify(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #23 0x00007f01c48a2c59 in QgsApplication::notify(QObject*, QEvent*) (this=0x7ffd4c3fe840, receiver=0x55e9bfb50cd0, event=0x7ffd4c3fd840) at ../src/core/qgsapplication.cpp:456
> done = true
> __PRETTY_FUNCTION__ = "virtual bool QgsApplication::notify(QObject*, QEvent*)"
> #24 0x00007f01c624ab62 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #25 0x00007f01c6ce9696 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #26 0x00007f01c6d3e36f in  () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #27 0x00007f01c6d407ae in  () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #28 0x00007f01c6ce503f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #29 0x00007f01c48a2c59 in QgsApplication::notify(QObject*, QEvent*) (this=0x7ffd4c3fe840, receiver=0x55e9c6e885a0, event=0x7ffd4c3fdc30) at ../src/core/qgsapplication.cpp:456
> done = true
> #30 0x00007f01c624ab62 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #31 0x00007f01c661245b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
> #32 0x00007f01c65e8c0b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
> #33 0x00007f0176de6b6a in  () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
> #34 0x00007f01bc067bab in g_main_context_dispatch () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
> #35 0x00007f01bc067e58 in  () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
> #36 0x00007f01bc067f0f in g_main_context_iteration () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
> #37 0x00007f01c62a02ff in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #38 0x00007f01c62494db in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #39 0x00007f01c6251782 in QCoreApplication::exec() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #40 0x000055e9bd489af2 in main(int, char**) (argc=3, argv=0x7ffd4c3ffbd8) at ../src/app/main.cpp:1637
> preApplicationLogMessages = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf02f070}, d = 0x55e9bf02f070}}, <No data fields>}
> __FUNCTION__ = "main"
> mySnapshotFileName = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> configLocalStorageLocation = {static null = {<No data fields>}, d = 0x55e9bf1fc270}
> profileName = {static null = {<No data fields>}, d = 0x55e9bf2032b0}
> mySnapshotWidth = 800
> mySnapshotHeight = 600
> myHideSplash = false
> settingsMigrationForce = false
> mySkipVersionCheck = false
> hideBrowser = false
> myRestoreDefaultWindowState = false
> myRestorePlugins = true
> myCustomization = true
> dxfOutputFile = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> dxfSymbologyMode = QgsDxfExport::SymbolLayerSymbology
> dxfScale = 50000
> dxfEncoding = {static null = {<No data fields>}, d = 0x55e9bd494b00 <main::{lambda()#2}::operator()() const::qstring_literal>}
> dxfMapTheme = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> dxfExtent = {mXmin = 0, mYmin = 0, mXmax = 0, mYmax = 0}
> takeScreenShots = false
> screenShotsPath = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> screenShotsCategories = 0
> myInitialExtent = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> translationCode = {static null = {<No data fields>}, d = 0x55e9bf1fa980}
> authdbdirectory = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> pythonfile = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> customizationfile = {static null = {<No data fields>}, d = 0x55e9bf6aea90}
> globalsettingsfile = {static null = {<No data fields>}, d = 0x55e9bf1fb220}
> openClProgramFolder = {static null = {<No data fields>}, d = 0x7f01c632b8a0 <QArrayData::shared_null>}
> args = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf1fa1a0}, d = 0x55e9bf1fa1a0}}, <No data fields>}
> myUseGuiFlag = true
> rootProfileFolder = {static null = {<No data fields>}, d = 0x55e9bf1fc140}
> manager = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c5292820 <qt_meta_stringdata_QgsUserProfileManager>, data = 0x7f01c52928a0 <qt_meta_data_QgsUserProfileManager>, static_metacall = 0x7f01c4322b60 <QgsUserProfileManager::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mWatchProfiles = false, mWatcher = std::unique_ptr<class QFileSystemWatcher> = {get() = 0x0}, mRootProfilePath = {static null = {<No data fields>}, d = 0x55e9bf1fc140}, mUserProfile = std::unique_ptr<class QgsUserProfile> = {get() = 0x0}, mSettings = std::unique_ptr<class QSettings> = {get() = 0x55e9bf1fa080}}
> profile = 0x55e9bf1fc4d0
> profileFolder = {static null = {<No data fields>}, d = 0x55e9bf1f7d10}
> myApp = {<QApplication> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c71d9160 <QApplication::staticMetaObject>}, stringdata = 0x7f01c527f0a0 <qt_meta_stringdata_QgsApplication>, data = 0x7f01c527f2a0 <qt_meta_data_QgsApplication>, static_metacall = 0x7f01c4308bd6 <QgsApplication::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, static QGIS_ORGANIZATION_NAME = 0x7f01c53c55da "QGIS", static QGIS_ORGANIZATION_DOMAIN = 0x7f01c53c55df "qgis.org", static QGIS_APPLICATION_NAME = 0x7f01c53c55e8 "QGIS3", static mFileOpenEventReceiver31500 = 0x55e9c02222c0, static mInitialized31500 = true, static mRunningFromBuildDir31500 = false, static sMaxThreads31500 = -1, mIconCache = {d = 0x55e9bf3ce2d0}, mCursorCache = {d = 0x55e9c0536b70}, mQgisTranslator = 0x55e9bf3d8f80, mQtTranslator = 0x55e9bf3d0fc0, mDataItemProviderRegistry = 0x55e9bfb4e290, mAuthManager = 0x55e9bfe65cc0, mApplicationMembers =
0x55e9bf3b7040, static sApplicationMembers = 0x0, static sAuthManager = 0x0}
> settings = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x7f01c528e460 <qt_meta_stringdata_QgsSettings>, data = 0x7f01c528e4a0 <qt_meta_data_QgsSettings>, static_metacall = 0x7f01c431e974 <QgsSettings::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mUserSettings = 0x55e9bf28b800, mGlobalSettings = 0x55e9bf228bc0, mUsingGlobalArray = false}
> libPaths = {<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x55e9bf91ddb0}, d = 0x55e9bf91ddb0}}, <No data fields>}
> relLibPath = {static null = {<No data fields>}, d = 0x55e9bf695c40}
> customizationsettings = 0x55e9bf91d4f0
> systemEnvVars = {d = 0x55e9bf2792a0}
> desiredStyle = {static null = {<No data fields>}, d = 0x55e9bf639510}
> activeStyleName = {static null = {<No data fields>}, d = 0x55e9bfe78da0}
> mySplashPath = {static null = {<No data fields>}, d = 0x7f01c53c66c0 <QgsApplication::splashPath()::{lambda()#1}::operator()() const::qstring_literal>}
> myPixmap = <incomplete type>
> w = 600
> h = 300
> mypSplash = 0x55e9bfee4270
> qgis = 0x55e9c02222c0
> sigwatch = {<QObject> = {<No data fields>}, static staticMetaObject = {d = {superdata = {direct = 0x7f01c64c9260 <QObject::staticMetaObject>}, stringdata = 0x55e9bd4d63c0 <qt_meta_stringdata_UnixSignalWatcher>, data = 0x55e9bd4d6480 <qt_meta_data_UnixSignalWatcher>, static_metacall = 0x55e9bd490ebe <UnixSignalWatcher::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, d_ptr = 0x55e9bfb3c190}
> retval = -1119002368
> [Inferior 1 (process 289397) detached]
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201016/190f6963/attachment-0001.html>
More information about the QGIS-Developer mailing list
