[QGIS-Developer] Difference between QgsVectorFileWriter and QgsOgrProvider when creating gpkg?
Even Rouault even.rouault at spatialys.com
Sat Oct 17 03:02:29 PDT 2020
Hi Nyall,
> But I can't explain this. In both cases the resultant gpkg has a
> spatial index. Does anyone know why one of the methods is so much
> slower than the other? (And ultimately, can we fix
> QgsVectorLayerExporter so it uses the same fast approach!)
Candidate fix and explanations at:
https://github.com/qgis/QGIS/pull/39439
Note that I haven't given this more than unit testing, but given what you
mentionned, I'm rather confident this should fix the issue.
Even
http://www.spatialys.com
More information about the QGIS-Developer mailing list
