[QGIS-Developer] How to save a DXF 3D using pyQgis ?
Matthias Kuhn
matthias at opengis.ch
Sun Oct 18 22:04:03 PDT 2020
You could also use QgsDxfExport, which exports a whole project.
https://qgis.org/api/classQgsDxfExport.html
Have a look at the tests for sample implementations:
https://github.com/qgis/QGIS/blob/master/tests/src/core/testqgsdxfexport.cpp
Best regards
Matthias
On Sun, Oct 18, 2020 at 7:07 PM Geo DrinX <geodrinx at gmail.com> wrote:
> Good evening to all,
> as in object, there is a way to save a DXF from a 3D polygon layer, using
> pyQgis ?
> I am using:
> QgsVectorFileWriter.writeAsVectorFormat(layer, file, "UTF-8", crsCrs,
> "DXF", overrideGeometryType=QgsWkbTypes.PolygonZ,skipAttributeCreation=True)
> but (also it works with other file types) the option
> "overrideGeometryType" seems to be irrilevant with DXF, and it saves in 2D.
> Someone can help me to discover the correct syntax ?
> Thank you in advance
> Roberto
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201019/6754ae4c/attachment.html>
