[QGIS-Developer] Build QGIS with MXE
Alessandro Pasotti apasotti at gmail.com
Sun Oct 18 23:48:45 PDT 2020
did you pull from elpaso/mxe-qt5-builder:latest ?
that works for me
On Sun, Oct 18, 2020 at 3:39 PM Theuns Heydenrych
<theunsheydenrych at gmail.com> wrote:
> HI
> I have followed the instructions on how to build QGIS with MXE.
> I have all the dependencies build via MXE
> I have changed the ms-windows/mxe/build-mxe.sh file to point the the MXE folder
> I have also changed the TARGET value, to the one I used in the MXE settings.mk file.
> I have checked out the release-3_10 branch of the QGIS repo
> When running the ms-windows/mxe/build-mxe.sh from within the QGIS folder I get the following error, the error output us in the file attached.
> Also attached I the modified_build-mxe.sh file.
> In the error output it shows that it try to use the following for a C compiler
> "/home/theuns/work/mxe/mxe/usr/x86_64-pc-linux-gnu/bin/x86_64-w64-mingw32.shared-gcc"
> and it fails with the error:
> ccache: error: Could not find compiler "x86_64-w64-mingw32.shared-gcc" in PATH
> I executed the command
> /home/theuns/work/mxe/mxe/usr/x86_64-pc-linux-gnu/bin/x86_64-w64-mingw32.shared-gcc in the same terminal and got the same result, "ccache: error: Could not find compiler "x86_64-w64-mingw32.shared-gcc" in PATH".
> I have checked the symbolic link to /home/theuns/work/mxe/mxe/usr/x86_64-pc-linux-gnu/bin/x86_64-w64-mingw32.shared-gcc and it looks fine, with executable rights and links to
> /home/theuns/work/mxe/mxe/.ccache/bin/ccache
> Please help, what can do to resolve this?
> I am using Ubuntu 20.04.
> Regards
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-Developer mailing list
