[QGIS-Developer] simple raster not showing on qgis
Idan Miara
idan at miara.com
Mon Oct 19 00:25:01 PDT 2020
I'm trying to load in QGIS the attached 24KB simple single byte raster (for
debugging gdal_calc.py)
It seems that it is valid, it has a non trivial histogram and it loads fine
in some picture viewers that I've tried, ms-paint, for instance.
But when I try to load it in QGIS (3.14 or 2.18) it seems as if the extent
is empty.
I zoom to extent and I see nothing, when I try to click on it with the
"Identify features" tool it shows nothing.
The histogram computed in QGIS also looks fine.
https://drive.google.com/file/d/1LKcQTsnqfW4Ouiqnd3WpOBtw5EeoIRUl/view?usp=sharing
Please advise,
Idan
gdalinfo -hist test_gdal_calc_py_9_1.tif
Driver: GTiff/GeoTIFF
Files: d:\dev\gis\gdal1\autotest\pyscripts\tmp\test_gdal_calc_py_9_1.tif
Size is 162, 150
Origin = (0.000000000000000,0.000000000000000)
Pixel Size = (1.000000000000000,1.000000000000000)
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 150.000)
Upper Right ( 162.0000000, 0.0000000)
Lower Right ( 162.000, 150.000)
Center ( 81.0000000, 75.0000000)
Band 1 Block=162x50 Type=Byte, ColorInterp=Gray
0...10...20...30...40...50...60...70...80...90...100 - done.
256 buckets from -0.5 to 255.5:
16777 819 118 48 4 7 12 76 159 156 120 122 140 111 104 95 88 91 95 81 68
93 66 66 81 57 72 61 70 69 68 59 69 88 60 56 38 69 58 56 55 54 52 62 61 51
51 36 46 43 42 47 52 48 32 50 42 32 44 33 34 39 29 36 20 24 26 26 24 18 35
24 32 34 35 39 44 28 28 29 31 34 30 22 30 18 18 28 28 20 21 19 21 31 17 27
17 19 25 22 19 17 17 11 13 18 16 16 15 17 21 12 7 19 12 17 12 15 21 13 13
17 11 11 13 13 13 15 10 15 15 17 8 11 7 7 9 11 10 8 10 12 11 8 7 5 10 5 5 6
5 9 12 3 6 9 6 8 7 7 11 6 8 9 7 10 1 4 6 6 7 7 4 6 5 6 3 12 6 3 3 6 9 6 3 5
7 8 1 2 2 2 3 4 4 5 3 4 3 2 3 2 3 1 5 5 2 3 3 5 3 4 2 2 2 5 3 5 2 3 4 2 8 5
5 10 3 3 4 3 4 7 2 7 4 9 9 16 18 13 13 7 23 17 20 22 51 77 51 45 37 45 40
56 68 0
NoData Value=255
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201019/6445fc7f/attachment.html>
