[QGIS-Developer] simple raster not showing on qgis
Idan Miara idan at miara.com
Mon Oct 19 06:27:46 PDT 2020
Thanks, @tim at kartoza.com <tim at kartoza.com>
https://github.com/qgis/QGIS/issues/39478
On Mon, 19 Oct 2020 at 16:09, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> Confirmed here:
> - shows in QGIS
> gdal_translate test_gdal_calc_py_9_1.tif -colorinterp red -of GTIFF
> test.tif - doesn't show in QGIS
> Probably best to open a ticket.
> Regards
> Tim
> On Mon, Oct 19, 2020 at 8:25 AM Idan Miara <idan at miara.com> wrote:
>> Hi,
>> I'm trying to load in QGIS the attached 24KB simple single byte raster
>> (for debugging gdal_calc.py)
>> It seems that it is valid, it has a non trivial histogram and it loads
>> fine in some picture viewers that I've tried, ms-paint, for instance.
>> But when I try to load it in QGIS (3.14 or 2.18) it seems as if the
>> extent is empty.
>> I zoom to extent and I see nothing, when I try to click on it with the
>> "Identify features" tool it shows nothing.
>> The histogram computed in QGIS also looks fine.
>> https://drive.google.com/file/d/1LKcQTsnqfW4Ouiqnd3WpOBtw5EeoIRUl/view?usp=sharing
>> Please advise,
>> Idan
>> gdalinfo -hist test_gdal_calc_py_9_1.tif
>> Driver: GTiff/GeoTIFF
>> Files: d:\dev\gis\gdal1\autotest\pyscripts\tmp\test_gdal_calc_py_9_1.tif
>> Size is 162, 150
>> Origin = (0.000000000000000,0.000000000000000)
>> Pixel Size = (1.000000000000000,1.000000000000000)
>> Image Structure Metadata:
>>   INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  (   0.0000000,   0.0000000)
>> Lower Left  (       0.000,     150.000)
>> Upper Right ( 162.0000000,   0.0000000)
>> Lower Right (     162.000,     150.000)
>> Center      (  81.0000000,  75.0000000)
>> Band 1 Block=162x50 Type=Byte, ColorInterp=Gray
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>>   256 buckets from -0.5 to 255.5:
>>   16777 819 118 48 4 7 12 76 159 156 120 122 140 111 104 95 88 91 95 81
>> 68 93 66 66 81 57 72 61 70 69 68 59 69 88 60 56 38 69 58 56 55 54 52 62 61
>> 51 51 36 46 43 42 47 52 48 32 50 42 32 44 33 34 39 29 36 20 24 26 26 24 18
>> 35 24 32 34 35 39 44 28 28 29 31 34 30 22 30 18 18 28 28 20 21 19 21 31 17
>> 27 17 19 25 22 19 17 17 11 13 18 16 16 15 17 21 12 7 19 12 17 12 15 21 13
>> 13 17 11 11 13 13 13 15 10 15 15 17 8 11 7 7 9 11 10 8 10 12 11 8 7 5 10 5
>> 5 6 5 9 12 3 6 9 6 8 7 7 11 6 8 9 7 10 1 4 6 6 7 7 4 6 5 6 3 12 6 3 3 6 9 6
>> 3 5 7 8 1 2 2 2 3 4 4 5 3 4 3 2 3 2 3 1 5 5 2 3 3 5 3 4 2 2 2 5 3 5 2 3 4 2
>> 8 5 5 10 3 3 4 3 4 7 2 7 4 9 9 16 18 13 13 7 23 17 20 22 51 77 51 45 37 45
>> 40 56 68 0
>>   NoData Value=255
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201019/fef33d8d/attachment.html>
More information about the QGIS-Developer mailing list
