[QGIS-Developer] Developer Best Practice Suggestions
Nyall Dawson nyall.dawson at gmail.com
Thu Oct 29 15:52:03 PDT 2020
On Fri, 30 Oct 2020 at 08:48, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 28 Oct 2020 at 23:34, C Hamilton <adenaculture at gmail.com> wrote:
> > I tried submitting my first QGIS core code submission. See
> > https://github.com/qgis/QGIS/pull/39655
> > As I was doing the pull request I found out that there were some scripts that should have been run to check the coding style. Unfortunately, those scripts are .sh scripts and I chose to develop on Windows using Visual Studio and as far as I know there isn't a way to run the scripts.
> > I am on windows, but would I be better off to use something like virtualbox and create a virtual linux development environment? I'm not as good with linux because I haven't used it for over 10 years.
> > Is there still a way for me to use the Windows development environment, yet make sure I'm able to run all the required scripts to do the checks?
> Yes -- there's two options:
> 1. (more hassle in the long run) Use cygwin and run the scripts
> through that. Make sure that you have the "with_astyle" cmake option
> enabled in your build too! Cygwin is easy to install, but it will be a
> pain to find all the required dependancies for the prepare commit
> script (e..g you'll need to get the perl packages)
> 2. (harder initially, less hassle in the long run) Install WSL and a
> Ubuntu release through that. Run the prepare commit script inside the
> Ubuntu shell. WSL takes a through hoops to install, but there's good
> guides out there. After you have the Ubuntu shell available it's easy
> to install all the required pacakges for the QGIS prepare commit
> scripts.
Oh, there's also shitty option #3:
3. Push your branch to github and find out what you need to change
through the failing tests. Manually make these changes to files.
Repeat.
Don't do 3. It's painful for you, painful for all the other devs (who
have to wait while your string of commits are run through the ci
before other PRs will get a chance), and it's **incredibly**
environmentally insensitive. Think of all the wasted CPU cycles and
the carbon cost of this approach!
Push through the hurdles and you'll find 1 or 2 works, and then you'll
never have to deal with the frustration of a development process based
on the third approach ;)
Nyall
> Personally when I'm doing dev on windows I always use the WSL ubuntu
> shell now, as it makes git/etc easier to use anyway!
> Nyall
> > How have you set up your QGIS development environment?
> > My code submission got a red flag with indentation so before I do anything more I really need to figure out the best workflow for doing development.
> > Thanks,
> > Calvin
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
