[QGIS-Developer] Pluriform-memory-layer?
Nyall Dawson nyall.dawson at gmail.com
Thu Oct 29 20:50:13 PDT 2020
On Fri, 30 Oct 2020 at 13:35, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> Hi Devs,
> Having 2 use cases currently:
> - A geocoder responding with a pluriform set of (geometry/feature) results: points, lines, polygons (3 different sets of attributes). See: [0]
> - A simple Line Of Sight analysis, resulting in a pluriform Geojson, holding: camera-viewpoint, fetched houses, selected centroids. See zipped attachment which you can paste into geojson.io [1] (or spread over 2 layers in QGIS) or see directly geojson.io if [2] works ...
> - And do not forget the often requested 'generic drawing layer'.
> I wondered...
> Would it be feasible/usable to have a special kind of memory layer / drawing layer which does NOT have the single type of GIS Feature constraint?
Yes. Recent QGIS versions have taken some steps towards making this
possible. Specifically, the 2d vector renderer is now completely
capable of rendering a layer with mixed geometry types, which is
probably the biggest hurdle here. We don't yet expose a "mixed
geometry" renderer type, but that could be added relatively easily.
The remaining part would be making sure we catch layers with a
"geometry collection" wkb type everywhere that's appropriate, and
either:
1. gracefully adapt to the actual feature's geometry type
or
2. prevent the user from running the tool on the layer.
I'd say the biggest focus here should be in processing. If we started
by just adding a general flag to processing vector inputs to indicate
that they can handle mixed geometry types, and then filter them out as
an option for non-compatible algorithms then we could later work on
each algorithm in turn which should support geometry collections.
We'd also need to decide what to do about layer edits, but I'd say
initially we just keep things simple and block edits on mixed geometry
layers.
Nyall
> So a layer which holds points, lines and polygons in one, with different (unique) types of attributes.
> So maybe a geojson (or maybe a drawingjson?) which would end up in one pluriform layer, style-able with rulebased styles?
> I do understand that this should not be a GIS-layer (as in not usable in analysis, showing attributes in a table etc)
> But it would be very convenient if multi-type (geo)json could be easily loaded in one layer and styled there (or create a drawing tool in which you can scribble some lines etc)
> Would this be worth a QEP or some discussion?
> Or would this mess up our 'model/world'?
> Seeing huge problems/issues?
> Regards,
> [0] https://github.com/qgis/QGIS/pull/38169#event-3938833355
> [1] http://geojson.io/
> [2] http://geojson.io/#data=data:application/json,%7B%22type%22%3A%20%22FeatureCollection%22%2C%20%22name%22%3A%20%22pand%22%2C%20%22crs%22%3A%20%7B%22type%22%3A%20%22name%22%2C%20%22properties%22%3A%20%7B%22name%22%3A%20%22urn%3Aogc%3Adef%3Acrs%3AOGC%3A1.3%3ACRS84%22%7D%7D%2C%20%22features%22%3A%20%5B%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647242%2C%2052.397173%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%2010195946%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.64713%2C%2052.396994%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542328%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647137%2C%2052.397041%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542326%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647162%2C%2052.397087%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542324%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647203%2C%2052.397133%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542322%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647304%2C%2052.397214%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542320%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647672%2C%2052.3977%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542284%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647598%2C%2052.397615%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542281%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647567%2C%2052.397576%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542280%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647506%2C%2052.397521%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542279%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647416%2C%2052.397417%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542278%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647118%2C%2052.397458%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542215%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647223%2C%2052.397684%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542207%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647619%2C%2052.397666%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205540259%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647332%2C%2052.397719%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205540239%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.646734%2C%2052.397441%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205541678%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647705%2C%2052.397752%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542285%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647393%2C%2052.397808%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205542204%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647435%2C%2052.397848%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205540237%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.647365%2C%2052.397762%5D%7D%2C%20%22properties%22%3A%20%7B%22id%22%3A%205540217%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.646879%2C%2052.396917%5D%2C%20%5B4.647237%2C%2052.3979%5D%2C%20%5B4.648169%2C%2052.397545%5D%2C%20%5B4.646879%2C%2052.396917%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22name%22%3A%20%22camera_resized%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.646879%2C%2052.396917%5D%2C%20%5B4.647177%2C%2052.397736%5D%2C%20%5B4.647954%2C%2052.39744%5D%2C%20%5B4.646879%2C%2052.396917%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22name%22%3A%20%22camera%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647294%2C%2052.397757%5D%2C%20%5B4.647403%2C%2052.397725%5D%2C%20%5B4.647434%2C%2052.397764%5D%2C%20%5B4.647436%2C%2052.397767%5D%2C%20%5B4.6474%2C%2052.397778%5D%2C%20%5B4.647329%2C%2052.397799%5D%2C%20%5B4.647294%2C%2052.397757%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205540217%2C%20%22identificatie%22%3A%20%220392100000043574%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20116%2C%20%22oppervlakte_max%22%3A%20116%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000043574%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647364%2C%2052.397842%5D%2C%20%5B4.647471%2C%2052.39781%5D%2C%20%5B4.647473%2C%2052.397813%5D%2C%20%5B4.647507%2C%2052.397854%5D%2C%20%5B4.6474%2C%2052.397886%5D%2C%20%5B4.647376%2C%2052.397858%5D%2C%20%5B4.647364%2C%2052.397842%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205540237%2C%20%22identificatie%22%3A%20%220392100000043596%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20109%2C%20%22oppervlakte_max%22%3A%20109%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000043596%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.64727%2C%2052.397924%5D%2C%20%5B4.647234%2C%2052.39788%5D%2C%20%5B4.647269%2C%2052.39787%5D%2C%20%5B4.647304%2C%2052.397914%5D%2C%20%5B4.64727%2C%2052.397924%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542203%2C%20%22identificatie%22%3A%20%220392100000045783%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045783%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647329%2C%2052.397799%5D%2C%20%5B4.6474%2C%2052.397778%5D%2C%20%5B4.647436%2C%2052.397767%5D%2C%20%5B4.647471%2C%2052.39781%5D%2C%20%5B4.647364%2C%2052.397842%5D%2C%20%5B4.647331%2C%2052.397851%5D%2C%20%5B4.647318%2C%2052.397833%5D%2C%20%5B4.647349%2C%2052.397824%5D%2C%20%5B4.647329%2C%2052.397799%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542204%2C%20%22identificatie%22%3A%20%220392100000045784%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20116%2C%20%22oppervlakte_max%22%3A%20116%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045784%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647234%2C%2052.39788%5D%2C%20%5B4.6472%2C%2052.397837%5D%2C%20%5B4.647235%2C%2052.397827%5D%2C%20%5B4.647269%2C%2052.39787%5D%2C%20%5B4.647234%2C%2052.39788%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542205%2C%20%22identificatie%22%3A%20%220392100000045785%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045785%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647167%2C%2052.397795%5D%2C%20%5B4.647215%2C%2052.397781%5D%2C%20%5B4.647229%2C%2052.397799%5D%2C%20%5B4.647182%2C%2052.397814%5D%2C%20%5B4.647167%2C%2052.397795%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542206%2C%20%22identificatie%22%3A%20%220392100000045786%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045786%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647616%2C%2052.397748%5D%2C%20%5B4.64772%2C%2052.397717%5D%2C%20%5B4.647728%2C%2052.397715%5D%2C%20%5B4.64773%2C%2052.397714%5D%2C%20%5B4.647749%2C%2052.397737%5D%2C%20%5B4.647782%2C%2052.397727%5D%2C%20%5B4.647785%2C%2052.397732%5D%2C%20%5B4.647798%2C%2052.39776%5D%2C%20%5B4.647771%2C%2052.397765%5D%2C%20%5B4.64768%2C%2052.397781%5D%2C%20%5B4.64765%2C%2052.39779%5D%2C%20%5B4.647616%2C%2052.397748%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542285%2C%20%22identificatie%22%3A%20%220392100000045876%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20114%2C%20%22oppervlakte_max%22%3A%20114%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045876%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647191%2C%2052.397788%5D%2C%20%5B4.647167%2C%2052.397795%5D%2C%20%5B4.647166%2C%2052.397794%5D%2C%20%5B4.647138%2C%2052.397759%5D%2C%20%5B4.647132%2C%2052.397753%5D%2C%20%5B4.647165%2C%2052.397743%5D%2C%20%5B4.647179%2C%2052.397739%5D%2C%20%5B4.647195%2C%2052.397759%5D%2C%20%5B4.647181%2C%2052.397763%5D%2C%20%5B4.647174%2C%2052.397766%5D%2C%20%5B4.647191%2C%2052.397788%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%2010284031%2C%20%22identificatie%22%3A%20%220392100000045787%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045787%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.646777%2C%2052.397601%5D%2C%20%5B4.646598%2C%2052.397657%5D%2C%20%5B4.646547%2C%2052.397595%5D%2C%20%5B4.646511%2C%2052.397606%5D%2C%20%5B4.64637%2C%2052.397434%5D%2C%20%5B4.646372%2C%2052.397434%5D%2C%20%5B4.646579%2C%2052.39737%5D%2C%20%5B4.646566%2C%2052.397354%5D%2C%20%5B4.64671%2C%2052.397309%5D%2C%20%5B4.646708%2C%2052.397305%5D%2C%20%5B4.646708%2C%2052.397301%5D%2C%20%5B4.646711%2C%2052.397297%5D%2C%20%5B4.646716%2C%2052.397293%5D%2C%20%5B4.646724%2C%2052.397291%5D%2C%20%5B4.646734%2C%2052.397291%5D%2C%20%5B4.64674%2C%2052.397292%5D%2C%20%5B4.646746%2C%2052.397295%5D%2C%20%5B4.646758%2C%2052.39731%5D%2C%20%5B4.646968%2C%2052.397245%5D%2C%20%5B4.64702%2C%2052.397308%5D%2C%20%5B4.647004%2C%2052.397313%5D%2C%20%5B4.647026%2C%2052.397341%5D%2C%20%5B4.647043%2C%2052.397335%5D%2C%20%5B4.647049%2C%2052.397334%5D%2C%20%5B4.647055%2C%2052.397334%5D%2C%20%5B4.647062%2C%2052.397335%5D%2C%20%5B4.647068%2C%2052.397337%5D%2C%20%5B4.647072%2C%2052.39734%5D%2C%20%5B4.647075%2C%2052.397344%5D%2C%20%5B4.647076%2C%2052.397347%5D%2C%20%5B4.647075%2C%2052.397351%5D%2C%20%5B4.647073%2C%2052.397355%5D%2C%20%5B4.647069%2C%2052.397358%5D%2C%20%5B4.647064%2C%2052.39736%5D%2C%20%5B4.647113%2C%2052.397421%5D%2C%20%5B4.646913%2C%2052.397483%5D%2C%20%5B4.646914%2C%2052.397485%5D%2C%20%5B4.646916%2C%2052.397491%5D%2C%20%5B4.646914%2C%2052.3975%5D%2C%20%5B4.646909%2C%2052.397506%5D%2C%20%5B4.646898%2C%2052.397512%5D%2C%20%5B4.646883%2C%2052.397515%5D%2C%20%5B4.646871%2C%2052.397515%5D%2C%20%5B4.646858%2C%2052.397511%5D%2C%20%5B4.646851%2C%2052.397507%5D%2C%20%5B4.646845%2C%2052.397503%5D%2C%20%5B4.646833%2C%2052.397487%5D%2C%20%5B4.64674%2C%2052.397516%5D%2C%20%5B4.646764%2C%2052.397545%5D%2C%20%5B4.64677%2C%2052.397543%5D%2C%20%5B4.646778%2C%2052.397541%5D%2C%20%5B4.646786%2C%2052.397541%5D%2C%20%5B4.646797%2C%2052.397544%5D%2C%20%5B4.646803%2C%2052.397548%5D%2C%20%5B4.646806%2C%2052.397556%5D%2C%20%5B4.646803%2C%2052.397562%5D%2C%20%5B4.646795%2C%2052.397568%5D%2C%20%5B4.646759%2C%2052.397579%5D%2C%20%5B4.646777%2C%2052.397601%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205541678%2C%20%22identificatie%22%3A%20%220392100000045123%22%2C%20%22bouwjaar%22%3A%201991%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22onderwijsfunctie%22%2C%20%22oppervlakte_min%22%3A%20410%2C%20%22oppervlakte_max%22%3A%201719%2C%20%22aantal_verblijfsobjecten%22%3A%202%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045123%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.64726%2C%2052.397715%5D%2C%20%5B4.647369%2C%2052.397681%5D%2C%20%5B4.647403%2C%2052.397725%5D%2C%20%5B4.647294%2C%2052.397757%5D%2C%20%5B4.64726%2C%2052.397715%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205540239%2C%20%22identificatie%22%3A%20%220392100000043598%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2086%2C%20%22oppervlakte_max%22%3A%2086%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000043598%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647547%2C%2052.39766%5D%2C%20%5B4.647649%2C%2052.397629%5D%2C%20%5B4.647656%2C%2052.397627%5D%2C%20%5B4.647689%2C%2052.397669%5D%2C%20%5B4.647691%2C%2052.397672%5D%2C%20%5B4.647685%2C%2052.397673%5D%2C%20%5B4.647581%2C%2052.397704%5D%2C%20%5B4.647547%2C%2052.39766%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205540259%2C%20%22identificatie%22%3A%20%220392100000043619%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20130%2C%20%22oppervlakte_max%22%3A%20130%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000043619%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647201%2C%2052.397649%5D%2C%20%5B4.647299%2C%2052.397619%5D%2C%20%5B4.647325%2C%2052.397626%5D%2C%20%5B4.647369%2C%2052.397681%5D%2C%20%5B4.64726%2C%2052.397715%5D%2C%20%5B4.647254%2C%2052.397717%5D%2C%20%5B4.647165%2C%2052.397743%5D%2C%20%5B4.647132%2C%2052.397753%5D%2C%20%5B4.647087%2C%2052.397697%5D%2C%20%5B4.647077%2C%2052.397687%5D%2C%20%5B4.647201%2C%2052.397649%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542207%2C%20%22identificatie%22%3A%20%220392100000045788%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20149%2C%20%22oppervlakte_max%22%3A%20149%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045788%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647111%2C%2052.397479%5D%2C%20%5B4.647087%2C%2052.39745%5D%2C%20%5B4.647126%2C%2052.397438%5D%2C%20%5B4.647149%2C%2052.397467%5D%2C%20%5B4.647111%2C%2052.397479%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542215%2C%20%22identificatie%22%3A%20%220392100000045797%22%2C%20%22bouwjaar%22%3A%201991%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045797%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647807%2C%2052.397679%5D%2C%20%5B4.647782%2C%2052.397626%5D%2C%20%5B4.647822%2C%2052.397619%5D%2C%20%5B4.647846%2C%2052.397672%5D%2C%20%5B4.647884%2C%2052.397665%5D%2C%20%5B4.647919%2C%2052.39774%5D%2C%20%5B4.64784%2C%2052.397753%5D%2C%20%5B4.647798%2C%2052.39776%5D%2C%20%5B4.647785%2C%2052.397732%5D%2C%20%5B4.647781%2C%2052.397727%5D%2C%20%5B4.647822%2C%2052.397714%5D%2C%20%5B4.647811%2C%2052.397688%5D%2C%20%5B4.647807%2C%2052.397679%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542249%2C%20%22identificatie%22%3A%20%220392100000045838%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22overige%20gebruiksfunctie%2C%20woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2018%2C%20%22oppervlakte_max%22%3A%20115%2C%20%22aantal_verblijfsobjecten%22%3A%202%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045838%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647865%2C%2052.397625%5D%2C%20%5B4.647886%2C%2052.397621%5D%2C%20%5B4.647892%2C%2052.397634%5D%2C%20%5B4.647951%2C%2052.397624%5D%2C%20%5B4.648%2C%2052.397726%5D%2C%20%5B4.647919%2C%2052.39774%5D%2C%20%5B4.647865%2C%2052.397625%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542250%2C%20%22identificatie%22%3A%20%220392100000045839%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20123%2C%20%22oppervlakte_max%22%3A%20123%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045839%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647808%2C%2052.397504%5D%2C%20%5B4.647887%2C%2052.39749%5D%2C%20%5B4.647898%2C%2052.397514%5D%2C%20%5B4.647819%2C%2052.397528%5D%2C%20%5B4.647808%2C%2052.397504%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542251%2C%20%22identificatie%22%3A%20%220392100000045840%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045840%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.648077%2C%2052.397713%5D%2C%20%5B4.648072%2C%2052.397713%5D%2C%20%5B4.648068%2C%2052.39772%5D%2C%20%5B4.648044%2C%2052.397724%5D%2C%20%5B4.648034%2C%2052.39772%5D%2C%20%5B4.648%2C%2052.397726%5D%2C%20%5B4.647964%2C%2052.397651%5D%2C%20%5B4.64796%2C%2052.397642%5D%2C%20%5B4.647952%2C%2052.397624%5D%2C%20%5B4.647941%2C%2052.397599%5D%2C%20%5B4.647977%2C%2052.397593%5D%2C%20%5B4.647988%2C%2052.397618%5D%2C%20%5B4.648028%2C%2052.397611%5D%2C%20%5B4.648041%2C%2052.397638%5D%2C%20%5B4.648077%2C%2052.397713%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542252%2C%20%22identificatie%22%3A%20%220392100000045841%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20123%2C%20%22oppervlakte_max%22%3A%20123%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045841%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.648078%2C%2052.397709%5D%2C%20%5B4.648075%2C%2052.39771%5D%2C%20%5B4.648041%2C%2052.397638%5D%2C%20%5B4.648039%2C%2052.397634%5D%2C%20%5B4.648028%2C%2052.397611%5D%2C%20%5B4.648014%2C%2052.397581%5D%2C%20%5B4.648046%2C%2052.397576%5D%2C%20%5B4.64806%2C%2052.397605%5D%2C%20%5B4.648068%2C%2052.397604%5D%2C%20%5B4.648079%2C%2052.397628%5D%2C%20%5B4.648116%2C%2052.397621%5D%2C%20%5B4.648152%2C%2052.397696%5D%2C%20%5B4.648078%2C%2052.397709%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542253%2C%20%22identificatie%22%3A%20%220392100000045842%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20121%2C%20%22oppervlakte_max%22%3A%20121%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045842%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.648116%2C%2052.397621%5D%2C%20%5B4.648105%2C%2052.397597%5D%2C%20%5B4.648092%2C%2052.397568%5D%2C%20%5B4.648122%2C%2052.397563%5D%2C%20%5B4.648136%2C%2052.397592%5D%2C%20%5B4.648147%2C%2052.397591%5D%2C%20%5B4.648158%2C%2052.397614%5D%2C%20%5B4.648193%2C%2052.397608%5D%2C%20%5B4.648229%2C%2052.397682%5D%2C%20%5B4.648152%2C%2052.397696%5D%2C%20%5B4.648116%2C%2052.397621%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542254%2C%20%22identificatie%22%3A%20%220392100000045843%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2089%2C%20%22oppervlakte_max%22%3A%2089%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045843%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.64783%2C%2052.397304%5D%2C%20%5B4.647909%2C%2052.397292%5D%2C%20%5B4.647941%2C%2052.39737%5D%2C%20%5B4.647964%2C%2052.397424%5D%2C%20%5B4.647929%2C%2052.39743%5D%2C%20%5B4.647919%2C%2052.397401%5D%2C%20%5B4.647873%2C%2052.397408%5D%2C%20%5B4.64783%2C%2052.397304%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542272%2C%20%22identificatie%22%3A%20%220392100000045864%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20118%2C%20%22oppervlakte_max%22%3A%20118%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045864%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647749%2C%2052.397314%5D%2C%20%5B4.647786%2C%2052.397309%5D%2C%20%5B4.647787%2C%2052.397311%5D%2C%20%5B4.64783%2C%2052.397304%5D%2C%20%5B4.647862%2C%2052.397382%5D%2C%20%5B4.647818%2C%2052.397389%5D%2C%20%5B4.647839%2C%2052.39744%5D%2C%20%5B4.647804%2C%2052.397446%5D%2C%20%5B4.647782%2C%2052.397394%5D%2C%20%5B4.647749%2C%2052.397314%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542273%2C%20%22identificatie%22%3A%20%220392100000045865%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20118%2C%20%22oppervlakte_max%22%3A%20118%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045865%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647669%2C%2052.397326%5D%2C%20%5B4.647675%2C%2052.397325%5D%2C%20%5B4.647676%2C%2052.397327%5D%2C%20%5B4.647723%2C%2052.39732%5D%2C%20%5B4.647722%2C%2052.397318%5D%2C%20%5B4.647749%2C%2052.397314%5D%2C%20%5B4.647803%2C%2052.397446%5D%2C%20%5B4.647766%2C%2052.397452%5D%2C%20%5B4.647745%2C%2052.3974%5D%2C%20%5B4.647702%2C%2052.397406%5D%2C%20%5B4.647669%2C%2052.397326%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542274%2C%20%22identificatie%22%3A%20%220392100000045866%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2095%2C%20%22oppervlakte_max%22%3A%2095%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045866%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647588%2C%2052.397338%5D%2C%20%5B4.647669%2C%2052.397326%5D%2C%20%5B4.647725%2C%2052.397463%5D%2C%20%5B4.64769%2C%2052.397468%5D%2C%20%5B4.647667%2C%2052.397412%5D%2C%20%5B4.647621%2C%2052.397419%5D%2C%20%5B4.647588%2C%2052.397338%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542275%2C%20%22identificatie%22%3A%20%220392100000045867%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20138%2C%20%22oppervlakte_max%22%3A%20138%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045867%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647591%2C%2052.397538%5D%2C%20%5B4.647583%2C%2052.39752%5D%2C%20%5B4.647623%2C%2052.397514%5D%2C%20%5B4.64763%2C%2052.397532%5D%2C%20%5B4.647591%2C%2052.397538%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542276%2C%20%22identificatie%22%3A%20%220392100000045868%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045868%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647432%2C%2052.397361%5D%2C%20%5B4.647505%2C%2052.39735%5D%2C%20%5B4.647534%2C%2052.397423%5D%2C%20%5B4.647496%2C%2052.397428%5D%2C%20%5B4.647507%2C%2052.397456%5D%2C%20%5B4.647474%2C%2052.397461%5D%2C%20%5B4.647462%2C%2052.397433%5D%2C%20%5B4.647432%2C%2052.397361%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542277%2C%20%22identificatie%22%3A%20%220392100000045869%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20108%2C%20%22oppervlakte_max%22%3A%20108%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045869%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647361%2C%2052.397383%5D%2C%20%5B4.647372%2C%2052.39737%5D%2C%20%5B4.647432%2C%2052.397361%5D%2C%20%5B4.647462%2C%2052.397433%5D%2C%20%5B4.647474%2C%2052.397461%5D%2C%20%5B4.647454%2C%2052.397464%5D%2C%20%5B4.647416%2C%2052.39747%5D%2C%20%5B4.647398%2C%2052.397474%5D%2C%20%5B4.647386%2C%2052.397444%5D%2C%20%5B4.647361%2C%2052.397383%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542278%2C%20%22identificatie%22%3A%20%220392100000045870%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20102%2C%20%22oppervlakte_max%22%3A%20102%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045870%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647431%2C%2052.397513%5D%2C%20%5B4.647447%2C%2052.397508%5D%2C%20%5B4.647477%2C%2052.397499%5D%2C%20%5B4.647514%2C%2052.397489%5D%2C%20%5B4.647506%2C%2052.39748%5D%2C%20%5B4.647535%2C%2052.397472%5D%2C%20%5B4.64756%2C%2052.397466%5D%2C%20%5B4.64758%2C%2052.397493%5D%2C%20%5B4.64753%2C%2052.397509%5D%2C%20%5B4.647561%2C%2052.397547%5D%2C%20%5B4.647553%2C%2052.397549%5D%2C%20%5B4.647477%2C%2052.397573%5D%2C%20%5B4.647431%2C%2052.397513%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542279%2C%20%22identificatie%22%3A%20%220392100000045871%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2035%2C%20%22oppervlakte_max%22%3A%2094%2C%20%22aantal_verblijfsobjecten%22%3A%203%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045871%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647477%2C%2052.397573%5D%2C%20%5B4.647553%2C%2052.397549%5D%2C%20%5B4.647578%2C%2052.397541%5D%2C%20%5B4.647584%2C%2052.397542%5D%2C%20%5B4.647587%2C%2052.397541%5D%2C%20%5B4.647609%2C%2052.397569%5D%2C%20%5B4.647678%2C%2052.397548%5D%2C%20%5B4.647691%2C%2052.397564%5D%2C%20%5B4.647614%2C%2052.397586%5D%2C%20%5B4.647512%2C%2052.397617%5D%2C%20%5B4.647511%2C%2052.397615%5D%2C%20%5B4.647477%2C%2052.397573%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542280%2C%20%22identificatie%22%3A%20%220392100000045872%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2093%2C%20%22oppervlakte_max%22%3A%2093%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045872%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647512%2C%2052.397617%5D%2C%20%5B4.647614%2C%2052.397586%5D%2C%20%5B4.647691%2C%2052.397564%5D%2C%20%5B4.647702%2C%2052.397578%5D%2C%20%5B4.647633%2C%2052.397599%5D%2C%20%5B4.647656%2C%2052.397627%5D%2C%20%5B4.647649%2C%2052.397629%5D%2C%20%5B4.647547%2C%2052.39766%5D%2C%20%5B4.647512%2C%2052.397617%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542281%2C%20%22identificatie%22%3A%20%220392100000045873%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20115%2C%20%22oppervlakte_max%22%3A%20115%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045873%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647788%2C%2052.397643%5D%2C%20%5B4.647751%2C%2052.397654%5D%2C%20%5B4.647727%2C%2052.397606%5D%2C%20%5B4.647765%2C%2052.397595%5D%2C%20%5B4.647788%2C%2052.397643%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542282%2C%20%22identificatie%22%3A%20%220392100000045874%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045874%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647581%2C%2052.397704%5D%2C%20%5B4.647685%2C%2052.397673%5D%2C%20%5B4.647788%2C%2052.397643%5D%2C%20%5B4.647794%2C%2052.397657%5D%2C%20%5B4.647702%2C%2052.397685%5D%2C%20%5B4.647723%2C%2052.397712%5D%2C%20%5B4.647728%2C%2052.397711%5D%2C%20%5B4.64773%2C%2052.397714%5D%2C%20%5B4.647728%2C%2052.397715%5D%2C%20%5B4.64772%2C%2052.397717%5D%2C%20%5B4.647616%2C%2052.397748%5D%2C%20%5B4.647581%2C%2052.397704%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542284%2C%20%22identificatie%22%3A%20%220392100000045875%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20115%2C%20%22oppervlakte_max%22%3A%20115%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045875%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647187%2C%2052.397207%5D%2C%20%5B4.647315%2C%2052.397187%5D%2C%20%5B4.647402%2C%2052.397173%5D%2C%20%5B4.647423%2C%2052.397225%5D%2C%20%5B4.647377%2C%2052.397231%5D%2C%20%5B4.647374%2C%2052.397224%5D%2C%20%5B4.647362%2C%2052.397199%5D%2C%20%5B4.647323%2C%2052.397206%5D%2C%20%5B4.647331%2C%2052.397226%5D%2C%20%5B4.647335%2C%2052.397237%5D%2C%20%5B4.647335%2C%2052.397239%5D%2C%20%5B4.647241%2C%2052.397252%5D%2C%20%5B4.647218%2C%2052.397248%5D%2C%20%5B4.647199%2C%2052.397223%5D%2C%20%5B4.647193%2C%2052.397209%5D%2C%20%5B4.647187%2C%2052.397207%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542320%2C%20%22identificatie%22%3A%20%220392100000045923%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2094%2C%20%22oppervlakte_max%22%3A%2094%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045923%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647116%2C%2052.397121%5D%2C%20%5B4.647235%2C%2052.3971%5D%2C%20%5B4.647257%2C%2052.397129%5D%2C%20%5B4.6473%2C%2052.397122%5D%2C%20%5B4.647307%2C%2052.397138%5D%2C%20%5B4.647268%2C%2052.397145%5D%2C%20%5B4.647266%2C%2052.397145%5D%2C%20%5B4.647152%2C%2052.397165%5D%2C%20%5B4.647116%2C%2052.397121%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542322%2C%20%22identificatie%22%3A%20%220392100000045925%22%2C%20%22bouwjaar%22%3A%201910%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2087%2C%20%22oppervlakte_max%22%3A%2087%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045925%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647085%2C%2052.397076%5D%2C%20%5B4.647201%2C%2052.397056%5D%2C%20%5B4.647204%2C%2052.397056%5D%2C%20%5B4.647205%2C%2052.397058%5D%2C%20%5B4.647217%2C%2052.397054%5D%2C%20%5B4.647233%2C%2052.397077%5D%2C%20%5B4.647221%2C%2052.397081%5D%2C%20%5B4.647235%2C%2052.3971%5D%2C%20%5B4.647116%2C%2052.397121%5D%2C%20%5B4.647093%2C%2052.397094%5D%2C%20%5B4.647085%2C%2052.397076%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542324%2C%20%22identificatie%22%3A%20%220392100000045927%22%2C%20%22bouwjaar%22%3A%201910%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20113%2C%20%22oppervlakte_max%22%3A%20113%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045927%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647064%2C%2052.397029%5D%2C%20%5B4.64718%2C%2052.397009%5D%2C%20%5B4.647182%2C%2052.397009%5D%2C%20%5B4.647183%2C%2052.39701%5D%2C%20%5B4.647196%2C%2052.397008%5D%2C%20%5B4.647206%2C%2052.397033%5D%2C%20%5B4.647194%2C%2052.397035%5D%2C%20%5B4.647204%2C%2052.397056%5D%2C%20%5B4.647201%2C%2052.397056%5D%2C%20%5B4.647085%2C%2052.397076%5D%2C%20%5B4.647064%2C%2052.397029%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542326%2C%20%22identificatie%22%3A%20%220392100000045929%22%2C%20%22bouwjaar%22%3A%201910%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2086%2C%20%22oppervlakte_max%22%3A%2086%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045929%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647042%2C%2052.396981%5D%2C%20%5B4.647155%2C%2052.396961%5D%2C%20%5B4.647161%2C%2052.39696%5D%2C%20%5B4.647163%2C%2052.396967%5D%2C%20%5B4.647171%2C%2052.396984%5D%2C%20%5B4.647228%2C%2052.396975%5D%2C%20%5B4.647239%2C%2052.396999%5D%2C%20%5B4.647182%2C%2052.397009%5D%2C%20%5B4.64718%2C%2052.397009%5D%2C%20%5B4.647064%2C%2052.397029%5D%2C%20%5B4.647042%2C%2052.396981%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542328%2C%20%22identificatie%22%3A%20%220392100000045931%22%2C%20%22bouwjaar%22%3A%201910%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2086%2C%20%22oppervlakte_max%22%3A%2086%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045931%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647385%2C%2052.39713%5D%2C%20%5B4.647391%2C%2052.397121%5D%2C%20%5B4.647451%2C%2052.397112%5D%2C%20%5B4.647455%2C%2052.397121%5D%2C%20%5B4.647492%2C%2052.397215%5D%2C%20%5B4.647423%2C%2052.397224%5D%2C%20%5B4.647402%2C%2052.397173%5D%2C%20%5B4.64739%2C%2052.397142%5D%2C%20%5B4.647385%2C%2052.39713%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205542372%2C%20%22identificatie%22%3A%20%220392100000045982%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%2097%2C%20%22oppervlakte_max%22%3A%2097%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000045982%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647897%2C%2052.397489%5D%2C%20%5B4.647962%2C%2052.397477%5D%2C%20%5B4.647973%2C%2052.397501%5D%2C%20%5B4.647908%2C%2052.397512%5D%2C%20%5B4.647897%2C%2052.397489%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205547612%2C%20%22identificatie%22%3A%20%220392100000051871%22%2C%20%22bouwjaar%22%3A%201920%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000051871%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647702%2C%2052.397578%5D%2C%20%5B4.647691%2C%2052.397564%5D%2C%20%5B4.647714%2C%2052.397557%5D%2C%20%5B4.647715%2C%2052.397578%5D%2C%20%5B4.647702%2C%2052.397578%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205556791%2C%20%22identificatie%22%3A%20%220392100000062075%22%2C%20%22bouwjaar%22%3A%201916%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22%22%2C%20%22oppervlakte_min%22%3A%200%2C%20%22oppervlakte_max%22%3A%200%2C%20%22aantal_verblijfsobjecten%22%3A%200%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000062075%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647505%2C%2052.39735%5D%2C%20%5B4.647588%2C%2052.397338%5D%2C%20%5B4.647621%2C%2052.397419%5D%2C%20%5B4.64763%2C%2052.39744%5D%2C%20%5B4.647546%2C%2052.397453%5D%2C%20%5B4.647534%2C%2052.397423%5D%2C%20%5B4.647505%2C%2052.39735%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%205560336%2C%20%22identificatie%22%3A%20%220392100000066227%22%2C%20%22bouwjaar%22%3A%201927%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20125%2C%20%22oppervlakte_max%22%3A%20125%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000066227%22%7D%7D%2C%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22Polygon%22%2C%20%22coordinates%22%3A%20%5B%5B%5B4.647324%2C%2052.397186%5D%2C%20%5B4.647315%2C%2052.397187%5D%2C%20%5B4.647187%2C%2052.397207%5D%2C%20%5B4.647186%2C%2052.397207%5D%2C%20%5B4.64718%2C%2052.397193%5D%2C%20%5B4.647168%2C%2052.397185%5D%2C%20%5B4.647152%2C%2052.397165%5D%2C%20%5B4.647268%2C%2052.397145%5D%2C%20%5B4.647304%2C%2052.397139%5D%2C%20%5B4.647324%2C%2052.397186%5D%5D%5D%7D%2C%20%22properties%22%3A%20%7B%22gid%22%3A%2010195946%2C%20%22identificatie%22%3A%20%220392100000043652%22%2C%20%22bouwjaar%22%3A%201910%2C%20%22status%22%3A%20%22Pand%20in%20gebruik%22%2C%20%22gebruiksdoel%22%3A%20%22woonfunctie%22%2C%20%22oppervlakte_min%22%3A%20110%2C%20%22oppervlakte_max%22%3A%20110%2C%20%22aantal_verblijfsobjecten%22%3A%201%2C%20%22rdf_seealso%22%3A%20%22http%3A//bag.basisregistraties.overheid.nl/bag/id/pand/0392100000043652%22%7D%7D%5D%2C%20%22metadata%22%3A%20%7B%22fetched%22%3A%2041%2C%20%22hits%22%3A%2020%2C%20%22scaled%22%3A%201.2%2C%20%22camera%22%3A%20%7B%22type%22%3A%20%22Feature%22%2C%20%22geometry%22%3A%20%7B%22type%22%3A%20%22GeometryCollection%22%2C%20%22geometries%22%3A%20%5B%7B%22type%22%3A%20%22Point%22%2C%20%22coordinates%22%3A%20%5B4.646879%2C%2052.396917%5D%7D%2C%20%7B%22type%22%3A%20%22LineString%22%2C%20%22coordinates%22%3A%20%5B%5B4.647177%2C%2052.397736%5D%2C%20%5B4.647954%2C%2052.39744%5D%5D%7D%5D%7D%2C%20%22properties%22%3A%20%7B%22angle%22%3A%2038.876645504061116%2C%20%22bearing%22%3A%2031.979981482645943%2C%20%22distance%22%3A%2087.9921646359149%7D%7D%7D%7D
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
