[QGIS-Developer] Unable to build QGIS master due to multiple definitions of sipQgs3DAlgorithms
DelazJ
delazj at gmail.com
Sat Oct 31 01:34:19 PDT 2020
Hi all,
Thanks Peter. I got some time to give it another try. So I trashed my build
dir and restarted.
Now I'm stuck at
*In file included from ../src/3d/qgsskyboxsettings.h:*
*23, from ../src/3d/qgs3dmapsettings.h:*
*33, from src/3d/qgis_3d_autogen/**EWIEGA46WW/moc_*
*qgs3dmapsettings.cpp:9, from src/3d/qgis_3d_autogen/mocs_*
*compilation.cpp:9:../src/3d/qgsskyboxentity.h:*
*22:10: fatal error: Qt3DExtras/QCuboidMesh: Aucun fichier ou dossier de ce
type 22 | #include <Qt3DExtras/QCuboidMesh> |
^~~~~~~~~~~~~~~~~~~~~~~~compilation terminated.[52/2925] Building CXX
object src/3d/CMakeFiles/qgis_3d.dir/**qgsabstractvectorlayer3drender*
*er.cpp.oninja: build stopped: subcommand failed.*
I don't know if it has anything to do but I had to fight against the "
Qt53DExtras" error to enable 3D
* CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
(find_package): Could not find a package configuration file provided by
"Qt53DExtras" with any of the following names:
Qt53DExtrasConfig.cmake qt53dextras-config.cmake Add the
installation prefix of "Qt53DExtras" to CMAKE_PREFIX_PATH or set
"Qt53DExtras_DIR" to a directory containing one of the above files. If
"Qt53DExtras" provides a separate development package or SDK, be sure it
has been installed. Call Stack (most recent call first):
CMakeLists.txt:404 (FIND_PACKAGE)*
Recipes I found in the list and the install file didn't seem to fix the
cmake so I set set the QT53DExtras_DIR to
/pathtoQGISrepo/external/qt3dextra-headers/cmake*/Qt53DExtras* (in which I
found the missing file)
Thanks for any suggestion.
Harrissou
Le jeu. 29 oct. 2020 à 14:01, Peter Petrik <
peter.petrik at lutraconsulting.co.uk> a écrit :
> Hi,
> can you please remove completely the build folder and start again?
> Thanks.
> P/
> On Thu, Oct 29, 2020 at 1:57 PM DelazJ <delazj at gmail.com> wrote:
>> Hi devs,
>> Since yesterday, I'm unable to build QGIS on Ubuntu 20.04 using ninja. It
>> used to work a couple of days ago.
>> I'm getting a bunch of errors of the type:
>> /usr/bin/ld :
>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart10.cpp.o : dans
>> la fonction « sipQgs3DAlgorithms::sipProtect_isSignalConnected(QMetaMethod
>> const&) const » :
>> /media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart10.cpp:4735 :
>> définitions multiples de
>> « sipQgs3DAlgorithms::sipProtect_isSignalConnected(QMetaMethod const&)
>> const »;
>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:/media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart8.cpp:892 :
>> défini pour la première fois ici
>> /usr/bin/ld :
>> la fonction
>> « sipQgs3DAlgorithms::sipProtect_addAlgorithm(QgsProcessingAlgorithm*) » :
>> /media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart10.cpp:4740 :
>> « sipQgs3DAlgorithms::sipProtect_addAlgorithm(QgsProcessingAlgorithm*) »;
>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:/media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart8.cpp:897 :
>> /usr/bin/ld :
>> la fonction « sipQgs3DAlgorithms::sipProtectVirt_loadAlgorithms(bool) » :
>> /media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart10.cpp:4745 :
>> « sipQgs3DAlgorithms::sipProtectVirt_loadAlgorithms(bool) »;
>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:/media/delazj/dev/github/QGIS/build_ninja/python/3d/sip_3dpart8.cpp:902 :
>> /usr/bin/ld :
>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart10.cpp.o:(.data.rel.local+0x2c0) :
>> définitions multiples de « sipTypeDef__3d_Qgs3DAlgorithms »;
>> python/CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart8.cpp.o:(.data.rel.local+0x160) :
>> collect2: error: ld returned 1 exit status
>> [59/1570] Linking CXX shared library output/lib/libqgis_gui.so.3.17.0
>> Any hints would be welcome. Thanks
>> Harrissou
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201031/33450154/attachment.html>
