[QGIS-Developer] Issue with determining Symbol size - Bug?
C Hamilton
adenaculture at gmail.com
Wed Sep 2 07:06:15 PDT 2020
Nyall,
Thanks. This almost gets the right answer.
QgsSymbolLayerUtils::estimateMaxSymbolBleed is returning 0 as its value.
I'm not sure what the problem is with it. bounds() seems to work for small
symbols which is probably all I'll need, but if the symbol is very large
with a large border and join style set to miter, the bounding box it
returns is a little too small. My example used an excessively large icon
and large border which probably would not be used in any real project.
Calvin
On Tue, Sep 1, 2020 at 6:39 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 2 Sep 2020 at 03:39, C Hamilton <adenaculture at gmail.com> wrote:
> > I am trying to calculate the size of a single symbol in pixels using:
> > canvas = iface.mapCanvas()
> > context = QgsRenderContext.fromMapSettings(canvas.mapSettings())
> > layer = iface.activeLayer()
> > rnd = layer.renderer()
> > sym = rnd.symbol()
> > scaled_size_in_pixels = context.convertToPainterUnits(
> > sym.size(),
> > sym.sizeUnit(),
> > sym.sizeMapUnitScale() )
> > The last line can also be calculated by:
> > scaled_size_in_pixels = sym.size(context)
> > I am finding that this is returning the size of the filled area of the
> symbol, but it does not include the border. Is this a bug or do I need to
> add something additional to include the border?
> You can use QgsSymbolLayerUtils::estimateMaxSymbolBleed if you're
> wanting to calculate the "maximum" bounding box of a rendered symbol.
> That includes any stroke/offset/other settings which also affect the
> rendered bounds.
> There's also QgsMarkerSymbol::bounds which returns an approximate
> bounding box of a marker symbol, which also accounts for things like
> the stroke and offset.
> Nyall
> > Thanks,
> > Calvin
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200902/80eeb9bc/attachment.html>
