[QGIS-Developer] QGIS Debug build fails to launch in QtCreator
Tim Sutton
tim at kartoza.com
Fri Sep 4 02:30:34 PDT 2020
Hi
Thanks for the fix Nyall. Ok cool, thanks for the fix! Now I can run in non
debug mode. In debug mode I get a bunch of these popping up:
The inferior stopped because it received a signal from the operating system.
Signal name :
SIG33
Signal meaning :
Real-time event 33
The execution pointer is just pointing at some disassembled code like:
0x7fffeaf9e376 <+ 534> 48 3d 00 f0 ff ff cmp
$0xfffffffffffff000,%rax
Which looks like it is a futex wait cancel something or other. If I click
OK then continue the debugger a bunch of times, eventually QGIS starts up.
Any idea how to make it move smoothly past those? I have disabled all
plugins and I still get the issue.
On Fri, Sep 4, 2020 at 12:45 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Fri, 4 Sep 2020 at 09:43, Tim Sutton <tim at kartoza.com> wrote:
> > Sorry my second message on this thread was probably a red herring - if I
> run as sudo QGIS starts fine....
> Grab this fix: https://github.com/qgis/QGIS/pull/38593
> Nyall
> > Regards
> > Tim
> > On Thu, Sep 3, 2020 at 11:48 PM Tim Sutton <tim at kartoza.com> wrote:
> >> Hi
> >> By the way poking around with it a bit more it seems to be crashing on
> this line @Nyal:
> >> 39fbc2ac331 src/core/qgsproject.cpp (Nyall Dawson
> 2020-08-31 10:30:20 +1000) mMainAnnotationLayer->setTransformContext(
> context );
> >> Regards
> >> Tim
> >> On Thu, Sep 3, 2020 at 10:02 PM Tim Sutton <tim at kartoza.com> wrote:
> >>> Dear QGIS Developers
> >>> I am trying to run QGIS in debug mode in Qt-Creator. When I launch the
> QGIS executable from QtCreator, I can see the application starting up but
> then after a short time it crashes out. This happens both when I press the
> green 'Run' triangle icon and when I press the green 'Start Debugging of
> Target Project' triangle icon.
> >>> I am building on pop_os! (essentially Ubuntu 20.04, 64 bit) using GCC
> without CCache and I have CMAKE_BUILD_TYPE set to Debug.
> >>> After starting QGIS it thinks for a while and then dies with the
> following (full log of messages here [1]).
> >>> 21:21:14: Debugging starts
> >>> src/app/main.cpp:505 : (main) [0ms] Starting qgis main
> >>> src/core/qgsmessagelog.cpp:29 : (logMessage) [379ms]
> 2020-09-03T21:21:45 [1] Successfully loaded globalsettingsfile path:
> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/qgis_global_settings.ini
> >>> src/core/qgscolorramp.cpp:732 : (loadFile) [103ms] filename=
> /home/timlinux/dev/cpp/QGIS-Debug-Build/output/data/resources/cpt-city-qgis-min/grass/elevation.svg
> loaded=0
> >>> QGIS died on signal 11Could not attach to process. If your uid
> matches the uid of the target
> >>> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or
> try
> >>> again as the root user. For more details, see
> /etc/sysctl.d/10-ptrace.conf
> >>> warning: process 223467 is already traced by process 223447
> >>> ptrace: Operation not permitted.
> >>> No thread selected
> >>> No stack.
> >>> gdb returned 256
> >>> 21:30:39: Debugging has finished
> >>> When I googled the ptrace error message above I found this
> StackOverflow post[2] which seems to address the same issue. However, even
> after trying all the various hints listed there, I still have the crash
> whenever I try to launch QGIS in debug mode, or outside of a debugger.
> >>> Has anyone else experienced this? Can you help me fix it?
> >>> Many thanks!
> >>> Regards
> >>> Tim
> >>> [1] https://gist.github.com/timlinux/ac7468675e08f18428e3fe60d7e9633c
> >>> [2]
> https://stackoverflow.com/questions/22120711/qt-creator-ptrace-operation-not-permitted-what-is-the-permanent-solution/30486572
> >>> Tim Sutton
> >>> Visit http://kartoza.com to find out about open source:
> >>> * Desktop GIS programming services
> >>> * Geospatial web development
> >>> * GIS Training
> >>> * Consulting Services
> >>> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> >>> Tim is a member of the QGIS Project Steering Committee
> >>> Kartoza is a merger between Linfiniti and Afrispatial
> >> Tim Sutton
> >> * GIS Training
> > Tim Sutton
> > * GIS Training
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200904/2349b1be/attachment.html>
