[QGIS-Developer] qgis build fails with cmake 3.18.2, NetBSD, quoting of $
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Sat Sep 12 12:24:01 PDT 2020
looks like duplicate of https://github.com/qgis/QGIS/pull/38103
I fixed it by using of ninja instead of make
P.
On Sat, Sep 12, 2020 at 7:17 PM Greg Troxel <gdt at lexort.com> wrote:
> I co-maintain the pkgsrc entry for qgis (and also look after proj, gdal,
> postgis).
> pkgsrc uses gmake because there are file names with spaces (json help),
> and there is some quoting problem with BSD make. (Also because of the
> present issue with $ quoting.)
> pkgsrc currently has 3.10.7 (yes, I know I should update to 3.10.10),
> which builds fine with cmake 3.17.3 on NetBSD, when qgis is built with
> gmake.
> With our current cmake 3.18.2 (or .1), the build fails because a
> generated makefile:
> work/qgis-3.10.7/build/src/core/CMakeFiles/qgis_core.dir/build.make
> escapes e.g. resources/function_help/json/$area to have four dollar signs:
> src/core/qgsexpression_texts.cpp:
> ../resources/function_help/json/$$$$area
> rather than the two $ that gmake expects. (However, BSD make, which we
> don't use, wants 4, for complicated and perhaps not valid reasons.)
> My working (but unsupported by reality) theory is that cmake is trying
> to accomodate BSD make and overquoting $, but is doing so because it is
> running on NetBSD, rather than because it knows BSD make will be used to
> build. However, I don't see this in the release notes.
> So far there have not been reports of other programs not building, but
> qgis is unusual in that it has files with $ in them.
> I am looking for a minimal fix to patch qgis or cmake to make this
> build.
> Hints would be appreciated on the following subjects:
> cmake really did or didn't change quoting of $
> The extra quoting is or isn't something somehow done by qgis.
> The questions I really should have asked, if I understtood this
> better.
> This is fixed in 3.10.10 :-)
> Thanks,
> Greg
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200912/73284d6c/attachment.html>
