[QGIS-Developer] CRS Selector: Specify CRS for layer Annotations ?
Raymond Nijssen
r.nijssen at terglobo.nl
Mon Sep 14 08:38:08 PDT 2020
Just filed the bug:
https://github.com/qgis/QGIS/issues/38739
@Werner
No, I tried with a new clean profile without plugins.
@Harrissou
Quite likely! :+1:
Raymond
On 14-09-2020 16:52, DelazJ wrote:
> Hi,
> Something to do with the annotation layer
> https://github.com/qgis/QGIS/pull/38021?
> Harrissou
> Le lun. 14 sept. 2020 à 16:51, Werner Macho <werner.macho at gmail.com
> <mailto:werner.macho at gmail.com>> a écrit :
> Hi Raymond,
> Have you checked if it is probably a plugin causing this?
> regards
> Werner
> On Mon, 2020-09-14 at 16:26 +0200, Raymond Nijssen wrote:
> > For a few weeks in QGIS master, when I start the application, when I
> > start a new empty project or (even) when I close the application,
> > the
> > CRS Selector Dialog pops up with the question:
> > It only happens when my CRS settings are set to: "Prompt for CRS"
> > for
> > new layers without CRS info.
> > So I guess something is creating a layer called "Annotations" in the
> > background. Tried to find it in the source code but I failed.
> > Anyone a clue?
> > Thanks!
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
