[QGIS-Developer] PG loading broken in master
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue Sep 15 08:40:59 PDT 2020
Hi Andreas,
Just a quick question: if both are present, should one be ignored? Which
auth configuration should be used in that case?
Regards,
Jorge
On 15/09/20 16:05, Andreas Neumann wrote:
> Ok -
> I am currently building older versions of master to find out which
> commit still worked.
> Will let you know, if I know more.
> Thanks,
> Andreas
> On 2020-09-15 17:02, Alessandro Pasotti wrote:
>> On Tue, Sep 15, 2020 at 4:52 PM Andreas Neumann <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>> wrote:
>>> Hi,
>>> Some recent commit broke all my projects that load PG layers with a
>>> datasource like:
>>> <datasource>service='pub' authcfg=sogis00 key='t_id' srid=2056
>>> type=Point checkPrimaryKeyUnicity='1' table="schema"."table"
>>> (geometrie) sql=</datasource>
>>> Means a combination of PG service name and auth config. None of the
>>> PG layers in the project can be loaded.
>>> Any idea what recent commit might be the culprit?
>> Sorry I don't, but I'm in bug fixing mode right now and working on
>> other PG issues, if you have any chance to let me debug your project
>> please let me know.
>> Cheers
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
