[QGIS-Developer] PG loading broken in master
Andreas Neumann a.neumann at carto.net
Wed Sep 16 01:38:28 PDT 2020
It seems like the second and third checkout from git bisect is now
between the good old start and the bad commit. So apparently only the
first checkout from git bisect was outside the range, the next one
inside. Perhaps this has to do with the fact that the checkouts need to
be dividable by a certain number?
Anyway - I'm getting closer to the culprit ;-)
Andreas
On 2020-09-16 10:28, Tim Sutton wrote:
> Hi
> Hmm I never had that problem - I just googled for a tutorial for you though so I didnt test to see if the tutorial was doing things correctly - you may want to try another source of info e.g.
> https://git-scm.com/docs/git-bisect
> Regards
> Tim
> On Wed, Sep 16, 2020 at 8:40 AM Andreas Neumann <a.neumann at carto.net> wrote:
> Ok - I am trying to learn git bisect, but I'm really confused to how it works:
> Here is what I did:
> $ git bisect start
> $ git bisect good c6e28828dd3c9d0459033643ced4ba8994d7bc92
> $ git bisect bad 1c2b4ae2b0f3add7767d473f2b4137d7de9afd24
> Bisecting: 18 revisions left to test after this (roughly 4 steps)
> [89e4d4925a7ff26561acde84a861986cb30af961] enable QgsMeshTriangulation with SIP and change SIP_CONCAT_PARTS
> Why on earth is git bisect checking out something older than the good commit? Really strange ...
> I would have expected that git bisect would check out something between the good and the bad commit.
> Confused ...
> Andreas
> On 2020-09-15 23:35, Tim Sutton wrote:
> Hi Andreas
> If you are not already aware of it, check out git bisect, which helps you to isolate a breaking commit quickly.
> https://www.metaltoad.com/blog/beginners-guide-git-bisect-process-elimination
> Regards
> Tim
> On Tue, 15 Sep 2020, 16:46 Andreas Neumann, <a.neumann at carto.net> wrote:
> Hi Jorge,
> There is only one authcfg. The service configuration doesn't contain auth information - just host, port and db. It is quite normal that you have a service name and an authcfg in the same data source.
> I am currently compiling older commits to find out which commit still worked.
> Probably I know more tomorrow.
> Greetings,
> Andreas
> On 2020-09-15 17:40, Jorge Gustavo Rocha wrote:
> Hi Andreas,
> Just a quick question: if both are present, should one be ignored? Which
> auth configuration should be used in that case?
> Regards,
> Jorge
> On 15/09/20 16:05, Andreas Neumann wrote: Ok -
> I am currently building older versions of master to find out which
> Will let you know, if I know more.
> Thanks,
> Andreas
> On 2020-09-15 17:02, Alessandro Pasotti wrote:
> On Tue, Sep 15, 2020 at 4:52 PM Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi,
> Some recent commit broke all my projects that load PG layers with a
> datasource like:
> <datasource>service='pub' authcfg=sogis00 key='t_id' srid=2056
> type=Point checkPrimaryKeyUnicity='1' table="schema"."table"
> (geometrie) sql=</datasource>
> Means a combination of PG service name and auth config. None of the
> PG layers in the project can be loaded.
> Any idea what recent commit might be the culprit?
> Sorry I don't, but I'm in bug fixing mode right now and working on
> other PG issues, if you have any chance to let me debug your project
> please let me know.
> Cheers
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Tim Sutton
Visit http://kartoza.com [1] to find out about open source:
 * Desktop GIS programming services
 * Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net [2]
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
Links:
[1] http://kartoza.com/
[2] http://freenode.net/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200916/ad230b82/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200916/ad230b82/attachment.gif>
More information about the QGIS-Developer mailing list
