[QGIS-Developer] Which qgis-dev in osgeo4w?
Jürgen E. Fischer
jef at norbit.de
Wed Sep 16 08:46:39 PDT 2020
Hi Paolo,
On Wed, 16. Sep 2020 at 17:13:52 +0200, Paolo Cavallini wrote:
> https://www.qgis.org/en/site/forusers/download.html
> that the nightly is called qgis-dev-full
> whereas in
> http://download.osgeo.org/osgeo4w/x86_64/versions.html
> it is called qgis-full-dev, but it does not seem up to date (2.99.0-2);
> qgis-dev, 3.15.0-54 might be the correct one. Should the website be updated?
> BTW, how can an user know which revision has been compiled, before
> actually installing it?
qgis-full-dev doesn't contain files. It's just a list of useful, but not
required qgis dependencies (eg. python extensions for plugins or gdal-ecw).
And it doesn't necessarily change which each release.
The result of the nightly builds is qgis-dev / qgis-rel-dev / qgis-ltr-dev.
And https://www.qgis.org/en/site/forusers/alldownloads.html has the SHAs of
those builds.
The standalone installers are made from the "full" packages, ie. contain more
packages than the bare minimum.
Jürgen
PS: the ongoing master build is for 8929e74a57, so it will have 1e715580af69.
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200916/e28834ef/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200916/e28834ef/attachment.ksh>
