[QGIS-Developer] Master build (landingPage?) issue
Richard Duivenvoorde
rdmailings at duif.net
Thu Sep 17 05:35:37 PDT 2020
Yep thanks, working again!
Richard
On 9/17/20 2:03 PM, Denis Rouzaud wrote:
> A refactoring and a fix have been merged at the same time.
> Fix is here: https://github.com/qgis/QGIS/pull/38835
> Le jeu. 17 sept. 2020 à 13:29, Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net>> a écrit :
> I'm building current maste (also clean build), but it stops with:
> [3342/4611] Building CXX object src/server/services/landingpage/CMakeFiles/landingpage.dir/qgslandingpageutils.cpp.o
> FAILED: src/server/services/landingpage/CMakeFiles/landingpage.dir/qgslandingpageutils.cpp.o
> ccache /usr/bin/c++ -DPROJ_VERSION_MAJOR=7 -DQGSMSDEBUG=1 -DQT_CONCURRENT_LIB -DQT_CORE_LIB -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050800 -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_CAST_TO_ASCII -DQT_POSITIONING_LIB -DQT_PRINTSUPPORT_LIB -DQT_SERIALPORT_LIB -DQT_SQL_LIB -DQT_SVG_LIB -DQT_WEBKITWIDGETS_LIB -DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB -DSIP_VERSION=0x041318 -DWITH_BINDINGS -DWITH_QTWEBKIT -Dlandingpage_EXPORTS -Isrc/server/services/landingpage/landingpage_autogen/include -I. -I../external -I../external/nlohmann -I../src/core -I../src/core/geometry -I../src/core/expression -I../src/core/symbology -I../src/core/metadata -I../src/core/layertree -I../src/server -I../src/server/services -I../src/server/services/landingpage -Isrc/core -Isrc/python -Isrc/server -Isrc/server/services/landingpage -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem
> /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtWebKitWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtWebKit -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem /usr/include/x86_64-linux-gnu/qt5/QtPositioning -Wall -Wextra -Wno-long-long -Wformat-security -Wno-strict-aliasing -Wnon-virtual-dtor -Wno-redundant-move -Wno-deprecated-copy -fvisibility=hidden -fvisibility-inlines-hidden -g -fPIC -fvisibility=hidden -fPIC -std=gnu++11 -MD -MT src/server/services/landingpage/CMakeFiles/landingpage.dir/qgslandingpageutils.cpp.o -MF
> src/server/services/landingpage/CMakeFiles/landingpage.dir/qgslandingpageutils.cpp.o.d -o src/server/services/landingpage/CMakeFiles/landingpage.dir/qgslandingpageutils.cpp.o -c ../src/server/services/landingpage/qgslandingpageutils.cpp
> ../src/server/services/landingpage/qgslandingpageutils.cpp: In static member function ‘static nlohmann::json QgsLandingPageUtils::projectInfo(const QString&)’:
> ../src/server/services/landingpage/qgslandingpageutils.cpp:459:85: error: ‘ExposeViaWfs’ is not a member of ‘QgsField::ConfigurationFlag’
> 459 | if ( !field.configurationFlags().testFlag( QgsField::ConfigurationFlag::ExposeViaWfs ) )
> [3351/4611] Automatic MOC for target qgis_gui
> Anybody a hint? I tried 'ninja clean' and a fresh build...
> Or is the build currently borken?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
