[QGIS-Developer] Is the spellcheck too greedy?
Alexandre Neto
senhor.neto at gmail.com
Mon Sep 28 17:27:17 PDT 2020
Hi Alessandro,
FYI, there's some json files that provide expressions functions help.
Therefore, if a white list is created, those should not be included.
Cheers,
Alexandre Neto
A segunda, 28/09/2020, 16:48, Alessandro Pasotti <apasotti at gmail.com>
escreveu:
> On Mon, Sep 28, 2020 at 5:41 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> > Hi Alessandro,
> > On Mon, 28. Sep 2020 at 17:10:56 +0200, Alessandro Pasotti wrote:
> > > I think that we should skip the spell check on a a list of file
> > > formats under the testdata directory:
> > > - xml
> > > - sql
> > > - json
> > > - html
> > > note that these are all under "tests/testdata" and they are not actual
> > > released or source code this means that there will be no consequences
> > > on the quality of our releases.
> > Remember ef1497faaa0dac55b1511c9aa06738c02b24884c ? ;)
> No, I've been bitten so many times by the spell check (and most of
> them for a reason) that I can't remember :)
> Anyway that commit does not exclude all SQL files, it actually
> excludes all files under the postgres raster testdata folder (which
> are all sql files btw).
> > Jürgen
> > Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> > Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> > Software Engineer D-26506 Norden
> https://www.norbit.de
> > QGIS release manager (PSC) Germany IRC: jef on
> FreeNode
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200929/0c54ee54/attachment.html>
