[QGIS-Developer] cppcheck false positive
Alessandro Pasotti
apasotti at gmail.com
Tue Sep 29 04:07:26 PDT 2020
On Tue, Sep 29, 2020 at 12:57 PM Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Side question, is there a technical reason to prefer this syntax over the = one?
> The = is more readable to me, but that's a matter of experience I guess.
> More generally, it would be nice to decide for one syntax and have a coherence over the source code.
> Cheers,
> Denis
Hi Denis,
I agree about the need for coherence, we currently have a mix of = ()
and {} initialization.
I'm not such an expert to tell you which is the best, but I've found
this explanations quite convincing:
https://isocpp.github.io/CppCoreGuidelines/CppCoreGuidelines#es23-prefer-the--initializer-syntax
https://stackoverflow.com/questions/18222926/why-is-list-initialization-using-curly-braces-better-than-the-alternatives
That is the reason why I switched to {} as my preferred method.
Cheers
> Le mar. 29 sept. 2020 à 11:55, Alessandro Pasotti <apasotti at gmail.com> a écrit :
>> Looks like cppcheck is not smart enough...
>> const double factor { std::pow( 10, - mPrecisionSpinBox->value() ) };
>> https://github.com/qgis/QGIS/pull/39079/checks?check_run_id=1181360827#step:4:1693
>> Alessandro Pasotti
>> QCooperative: www.qcooperative.net
>> ItOpen: www.itopen.it
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
