[QGIS-Developer] QgsO2 (OAuth2 ) crash in exitQgis() on uWSGI
Alessandro Pasotti
apasotti at gmail.com
Mon Apr 26 04:25:12 PDT 2021
On Mon, Apr 26, 2021 at 1:19 PM Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi,
> we are getting crash in OAuth2 plugin when QgsApplication.exitQgis()
> is called from Django application running on uWSGI/nginx. We need to
> call exitQgis() to cleanup temporary files. It works OK if it is run
> as Django script from command line.
> Unfortunately it does not print full backtrace info for
> liboauth2authmethod.so and then even for libqgis_core.so. I guess it
> happens in QgsO2 but there is nothing suspicious in that code.
> /usr/bin/uwsgi-core(uwsgi_backtrace+0x2a) [0x560f2dbf4dda]
> /usr/bin/uwsgi-core(uwsgi_segfault+0x23) [0x560f2dbf51c3]
> /lib/x86_64-linux-gnu/libc.so.6(+0x37840) [0x7fb7be828840]
> /lib/libqgis_core.so.3.18.1(+0x3a2496) [0x7fb782844496]
> /usr/lib/qgis/plugins/liboauth2authmethod.so(+0x225c0) [0x7fb77404c5c0]
> /usr/lib/qgis/plugins/liboauth2authmethod.so(+0x2b317) [0x7fb774055317]
> /usr/lib/qgis/plugins/liboauth2authmethod.so(+0x2b5b9) [0x7fb7740555b9]
> /lib/libqgis_core.so.3.18.1(_ZN14QgsAuthManagerD1Ev+0x437) [0x7fb782afb847]
> Any idea how to fix it? Any workaround? How can i get full debug info?
> We have qgis and qgis-dbg 3.18.1 installed from qgis.org/debian.
Hi Radim,
no clues sorry, but if you don't need the oauth2 plugin you can just rm/mv
the liboauth2authmethod.so and you should be fine.
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210426/3b43246d/attachment.html>
