[QGIS-Developer] reload QGIS Server plugin
Andreas Neumann
a.neumann at carto.net
Wed Apr 28 00:11:07 PDT 2021
No - "_systemctl daemon-reload_" is only useful and recommended if you
change something in your daemon/service configuration, which is not the
case when you want to reload a QGIS server plugin.
It should be enough to reload or restart your webserver:
systemctl reload nginx
or
systemctl restart nginx
or whatever the nginx webserver daemon is called on your system.
Greetings,
Andreas
On 2021-04-28 08:43, michal.wloga at envirosolutions.pl wrote:
> Regarding to my question I found an answer:
> The following command seems to be sufficient:
> Regards,
> EnviroSolutions Sp. z o. o.
> Michał Włoga
> tel: +48 607 059 157
> coo at envirosolutions.pl
> www.envirosolutions.pl [1]
> Pobieracz Danych GUGiK [2] - laureat nagrody GUGiK na najlepsze
> wykorzystanie danych i usług GUGiK w 2020 r.
> From: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] On
> Behalf Of michal.wloga at envirosolutions.pl
> Sent: Wednesday, April 28, 2021 8:12 AM
> To: qgis-developer at lists.osgeo.org
> Subject: [QGIS-Developer] reload QGIS Server plugin
> Hello,
> I have QGIS Server installed on ubuntu 20 with nginx + sockets. Is
> there a way to reload a server plugin other than restarting the host?
> Regards,
> Michał Włoga
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Links:
[1] http://www.envirosolutions.pl/szkolenia
[2]
https://www.envirosolutions.pl/news/118/129/Wtyczka-QGIS---Pobieracz-Danych-GUGiK.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210428/d62e3b65/attachment.html>
