[QGIS-Developer] QGIS Date, Time and Time Zones
C Hamilton adenaculture at gmail.com
Thu Apr 29 11:28:14 PDT 2021
Thanks for the reply. That certainly places a lot of limits on what can and
cannot be done.
Calvin
On Thu, Apr 29, 2021 at 2:18 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> >  but the question I have is whether a vector layer were saved to
> > something like a GPKG would the timezone even be preserved?
> Short answer: not by default
> Longer answer:
> - see https://github.com/opengeospatial/geopackage/issues/530
> - and https://github.com/OSGeo/gdal/issues/3423#issuecomment-772405674
> - and https://gdal.org/drivers/vector/gpkg.html#dataset-creation-options
> So basically:
> - the GeoPackage spec only supports date/time encoded as ISO 8601 with
> Zulu timezone : "YYYY-MM-DDTHH:MM:SS.SSSZ"
> - on reading side, the OGR Geopackage driver can understand non-Zulu
> timezones
> - on writing side, by default the OGR Geopackage driver will convert
> datetimes to the Zulu timezone (applying the appropriate shift), unless
> the DATETIME_FORMAT=WITH_TZ dataset creation option is passed at
> creation time, in which case the original timezone is preserved. Such
> datasets may not be read correctly by third party implementations.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210429/a86bcb7b/attachment.html>
More information about the QGIS-Developer mailing list
