[QGIS-Developer] reload QGIS Server plugin
Andreas Neumann
andreas at qgis.org
Fri Apr 30 06:11:02 PDT 2021
Hi Michał,
Which one does not work? The "reload" or the "restart" command?
The latter should definitely work - otherwise I am really puzzled ...
Greetings,
Andreas
On Fri, 30 Apr 2021 at 14:54, <michal.wloga at envirosolutions.pl> wrote:
> Hi Andreas,
> Unfortunately your approach does not work (mine also).
> Some threads of QGIS Server have not updated a plugin so that I’m
> receiving different responses from QGIS Server when using different
> sockets.
> Regards,
> EnviroSolutions Sp. z o. o.
> Michał Włoga
> tel: +48 607 059 157
> coo at envirosolutions.pl
> www.envirosolutions.pl <http://www.envirosolutions.pl/szkolenia>
> Pobieracz Danych GUGiK
> <https://www.envirosolutions.pl/news/118/129/Wtyczka-QGIS---Pobieracz-Danych-GUGiK.html>
> – laureat nagrody GUGiK na najlepsze wykorzystanie danych i usług GUGiK w
> 2020 r.
> *From:* Andreas Neumann [mailto:a.neumann at carto.net]
> *Sent:* Wednesday, April 28, 2021 9:11 AM
> *To:* michal.wloga at envirosolutions.pl
> *Cc:* qgis-developer at lists.osgeo.org
> *Subject:* Re: [QGIS-Developer] reload QGIS Server plugin
> Hi,
> No - "*systemctl daemon-reload*" is only useful and recommended if you
> change something in your daemon/service configuration, which is not the
> case when you want to reload a QGIS server plugin.
> It should be enough to reload or restart your webserver:
> systemctl reload nginx
> or
> systemctl restart nginx
> or whatever the nginx webserver daemon is called on your system.
> Greetings,
> Andreas
> On 2021-04-28 08:43, michal.wloga at envirosolutions.pl wrote:
> Regarding to my question I found an answer:
> The following command seems to be sufficient:
> Regards,
> Michał Włoga
> 2020 r.
> *From:* QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org
> <qgis-developer-bounces at lists.osgeo.org>] *On Behalf Of *
> *Sent:* Wednesday, April 28, 2021 8:12 AM
> *To:* qgis-developer at lists.osgeo.org
> *Subject:* [QGIS-Developer] reload QGIS Server plugin
> Hello,
> I have QGIS Server installed on ubuntu 20 with nginx + sockets. Is there a
> way to reload a server plugin other than restarting the host?
> Regards,
> Michał Włoga
> 2020 r.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210430/ba9662e1/attachment.html>
