[QGIS-Developer] QgsTriangle.angles() return wrong values ?
Loïc Bartoletti
lbartoletti at tuxfamily.org
Sun Dec 5 02:34:35 PST 2021
Salut Nicolas,
I think I added this very strange hack when I ported my old python code
(with other geometry functions that were not or slightly different from
QgsGeometryUtils). However, I have no memory of why.
You can open an issue and assign it to me, I will try to find that old
code and fix it. We can discuss this later this week.
Loïc
Le 04/12/2021 à 20:32, Nicolas Godet a écrit :
> A workaround would be to add 90° to the lowest value if the sum is
> lower than 180°.
> https://github.com/Artelia/Mesh_tools/commit/5d40a8807f1c8264ccff51b365ce8d58ac333011
> That’s not ideal, especially in case of very flat triangle…
>> Le 4 déc. 2021 à 19:52, Nicolas Godet <nicolas.godet at outlook.fr> a
>> écrit :
>> Seems an issue more than a feature to me.
>> At least, the doc should reflect this behavior.
>> Should I open a issue on GH ?
>>> Le 4 déc. 2021 à 19:45, Andrea Giudiceandrea <andreaerdna at libero.it>
>>> a écrit :
>>> Il 04/12/2021 13:52, Nicolas Godet ha scritto:
>>>> >>> triangle.angles()
>>>> [0.7119509950830287, 0.0008857138004074727, 0.85795961791146]
>>>> >>> [math.degrees(a) for a in triangle.angles()]
>>>> [40.79178723839677, 0.05074766261984076, 49.157465098983366]
>>>> We should have a near-90° angle, which we don't...
>>> Hi Nicolas,
>>> it seems the QgsTriangle::angles() fails to correctly return the
>>> value of angles greater than 90° deg. (Pi/2 rad.).
>>> Actually the function code strangely subtract 90 to such angles:
>>> https://github.com/qgis/QGIS/blob/dd0cd13a00998bc153c0b6519ea75038b57a6df5/src/core/geometry/qgstriangle.cpp#L397-L403
>>> angles.append( ( a1 > M_PI_2 ? a1 - M_PI_2 : a1 ) );
>>> angles.append( ( a2 > M_PI_2 ? a2 - M_PI_2 : a2 ) );
>>> angles.append( ( a3 > M_PI_2 ? a3 - M_PI_2 : a3 ) );
>>> In fact, the correct value of the angle is 90.05074766261984076 deg.
>>> and not 0.05074766261984076.
>>> Regards.
>>> Andrea
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211205/e1658ebb/attachment.html>
