[QGIS-Developer] QGIS server landing page when running as fastcgi?
Alessandro Pasotti
apasotti at gmail.com
Tue Feb 2 04:58:39 PST 2021
This looks bad:
./src/core/qgsproviderregistry.cpp:179 : (init) [0ms] No dynamic QGIS
data provider plugins found in:
/usr/lib/qgis/plugins
and:
No authentication methods can be used. Check your QGIS installation
Fix your prefix path.
QGIS_SERVER_API_RESOURCES_DIRECTORY is for overrides, if you have
custom templates.
On Tue, Feb 2, 2021 at 1:49 PM Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 2/2/21 12:41 PM, Alessandro Pasotti wrote:
> > On Tue, Feb 2, 2021 at 12:34 PM Richard Duivenvoorde
> >> Hi (Server)Devs,
> >> When I run the minimal qgis_mapserver and go to http://localhost:8000 QGIS server presents me the nice "QGIS Server Catalog" landingpage.
> >> But installing (the exact same) qgis server as fast-cgi in my local apache I do NOT get that....
> > Hi Richard,
> > ... and you get what?
> IF I provide a qgz file (+data) in the /usr/lib/cgi-bin dir, I get the (xml) error message:
> Service unknown or unsupported. Current supported services (case-sensitive): WMS WFS WCS WMTS SampleService, or use a WFS3 (OGC API Features) endpoint
> If I at that moment go to
> http://localhost/cgi-bin/qgis_mapserv.fcgi/wfs3/
> I get the Collections "landing page" with the layers in the qgz next to the fastcgi
> (note I am trying to get the "QGIS Server Catalog" landingpage)
> >> Do I have to enable the QGIS_PLUGINPATH env var?
> > nope: landing page is not a python plugin.
> Ok, was not clear to me that this was a PYTHON plugin path...
> https://www.qgis.org/en/site/forusers/visualchangelog316/index.html#qgis-server-landing-page-plugin
> states: "A Landing Page Plugin for QGIS Server was created" that is the reason I still though it was a plugin..
> >> I tried to set it to the "/build/output/data/" or "/build/output/data/resources" as there are some js files there for the server...
> >> Going to http://localhost/cgi-bin/qgis_mapserv.fcgi/wfs3/ I get a landing page, but that one is different from the "QGIS Server Catalog" which I have if I run qgis_mapserver.
> > yeah, that's the WFS3/OAPIF landing page, dictated by the standar.
> >> Any hints?
> > It depends on what you actually get instead of the landing page.
> > Try checking the logs, the landing page is pretty chatty.
> I still do not have the magic combi of ENVIRONMENT variables to get the QGIS server log (other then in my apache error log) :-(
> I do find some more environment variables now:
> https://docs.qgis.org/testing/en/docs/server_manual/config.html#qgis-server-logging
> Is the
> needed for this landing page? Tried: failed :-(
> (note: never heard/used of spawn-fcgi ... is that the way to show the vars used by the server?)
> $ spawn-fcgi -f /usr/lib/cgi-bin/qgis_mapserv.fcgi -s /tmp/qgisserver.sock -U www-data -G www-data -n
> Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
> - 'VirtualXPath' [XML Path Language - XPath]
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [93ms] 2021-02-02T13:41:32 Server[0] QGIS Server Settings:
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_OPTIONS_PATH / '' (Override the default path for user configuration): '' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_PARALLEL_RENDERING / '/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS getMap request): 'true' (read from INI_FILE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_MAX_THREADS / '/qgis/max_threads' (Number of threads to use when parallel rendering is activated): '-1' (read from INI_FILE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_LOG_LEVEL / '' (Log level): '4' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_LOG_FILE / '' (Log file): '' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_LOG_STDERR / '' (Activate/Deactivate logging to stderr): 'false' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_PROJECT_FILE / '' (QGIS project file): '' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_IGNORE_BAD_LAYERS / '' (Ignore bad layers): 'false' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_CACHE_DIRECTORY / '/cache/directory' (Specify the cache directory): '/home/richard/.local/share/QGIS/QGIS3/profiles/default/cache' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_CACHE_SIZE / '/cache/size' (Specify the cache size): '52428800' (read from INI_FILE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_SHOW_GROUP_SEPARATOR / '/locale/showGroupSeparator' (Show group (thousands) separator): 'false' (read from INI_FILE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE / '/locale/userLocale' (Override system locale): 'en_US' (read from INI_FILE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_WMS_MAX_HEIGHT / '/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of this and the project configuration is used.): '-1' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_WMS_MAX_WIDTH / '/qgis/max_wms_width' (Maximum width for a WMS request. The most conservative between this and the project one is used): '-1' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_API_RESOURCES_DIRECTORY / '/qgis/server_api_resources_directory' (Base directory where HTML templates and static assets (e.g. images, js and css files) are searched for): '/usr/share/qgis/resources/server/api' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_API_WFS3_MAX_LIMIT / '/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_TRUST_LAYER_METADATA / '' (Trust layer metadata): 'false' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_DISABLE_GETPRINT / '' (Don't load layouts): 'false' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_LANDING_PAGE_PROJECTS_DIRECTORIES / '/qgis/server_projects_directories' (Directories used by the landing page service to find .qgs and .qgz projects): '' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_LANDING_PAGE_PROJECTS_PG_CONNECTIONS / '/qgis/server_projects_pg_connections' (PostgreSQL connection strings used by the landing page service to find projects): '' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] - QGIS_SERVER_LOG_PROFILE / '/qgis/server_log_profile' (Add detailed profile information to the logs, only effective when QGIS_SERVER_LOG_LEVEL=0): 'false' (read from DEFAULT_VALUE)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] Ini file used to initialize settings: /home/richard/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [83ms] 2021-02-02T13:41:32 Server[0] cacheDirectory: /home/richard/.local/share/QGIS/QGIS3/profiles/default/cache/
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] maximumCacheSize: 52428800
> ../src/core/qgsproviderregistry.cpp:179 : (init) [0ms] No dynamic QGIS data provider plugins found in:
> ../src/core/qgsproviderregistry.cpp:267 : (init) [0ms] Loaded 6 providers (ept;gdal;memory;mesh_memory;ogr;vectortile)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [18ms] 2021-02-02T13:41:32 Server[0] Prefix PATH: /usr
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] Plugin PATH: /usr/lib/qgis/plugins
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] PkgData PATH: /usr/share/qgis
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] User DB PATH: /home/richard/.local/share/QGIS/QGIS3/profiles/default/qgis.db
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] Auth DB PATH: /home/richard/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] SVG PATHS: /home/richard/bin/qgis_/master/debug/share/qgis/svg/:/home/richard/.local/share/QGIS/QGIS3/profiles/default/resource_sharing/collections:/home/richard/.local/share/QGIS/QGIS3/profiles/default/svg/:/home/richard/bin/geoserver/geoserver-2.15.2/data_dir/styles:/home/richard/git/qgisqt2/build/debug/output/data/svg/:/home/richard/git/qgisqt2/svg/:/home/richard/bin/qgis_/3.10/debug/share/qgis/svg/:/home/richard/git/build-qgisqt-Desktop-Debug/output/data/svg/:/home/richard/git/qgisqt/svg/:/svg/:/home/richard/bin/qgis_/3.16/debug/share/qgis/svg/:/home/richard/git/build-qgisqt2-Desktop-Debug/output/data/svg/:/home/richard/git/build-qgisqt3-Desktop-Debug/output/data/svg/:/home/richard/git/qgisqt3/svg/:/usr/share/qgis/svg/
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [19ms] 2021-02-02T13:41:32 No Authentication Methods[1] No QGIS auth method plugins found in:
> ../src/core/auth/qgsauthmanager.cpp:483 : (isDisabled) [0ms] Authentication system DISABLED: QCA's qca-ossl (OpenSSL) plugin is missing
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [68ms] 2021-02-02T13:41:32 Server[0] Server initialized
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 ../src/server/qgsserverplugins.cpp[0] load library /usr/lib/qgispython (3.17.0)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 [1] Couldn't load Python support library: Cannot load library /usr/lib/qgispython: (/usr/lib/libqgispython.so: cannot open shared object file: No such file or directory)
> ../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms] 2021-02-02T13:41:32 Server[0] No server python plugins are available
> Testing with all this magic:
> FcgidIOTimeout 120
> FcgidInitialEnv LC_ALL "en_US.UTF-8"
> FcgidInitialEnv PYTHONIOENCODING UTF-8
> FcgidInitialEnv LANG "en_US.UTF-8"
> FcgidInitialEnv QGIS_DEBUG 5
> FcgidInitialEnv QGIS_SERVER_LOG_FILE "/tmp"
> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 5
> #FcgidInitialEnv QGIS_PROJECT_FILE "/usr/lib/cgi-bin/cbsgemeenten2018.qgz" # with or without this one that project is loaded
> FcgidInitialEnv QGIS_SERVER_LANDING_PAGE_PROJECTS_DIRECTORIES "/tmp/qgisserver"
> FcgidInitialEnv QGIS_OPTIONS_PATH "/tmp"
> FcgidInitialEnv QGIS_SERVER_CACHE_DIRECTORY "."
> FcgidInitialEnv QGIS_SERVER_API_RESOURCES_DIRECTORY "/home/richard/git/qgis/build/output/data/"
> FcgidInitialEnv PYTHONPATH "/home/richard/bin/qgis_/master/debug/share/qgis/python"
> FcgidInitialEnv LD_LIBRARY_PATH "/home/richard/bin/qgis_/master/debug/lib/:/home/richard/bin/gdal/lib"
> FcgidInitialEnv QGIS_PREFIX_PATH "/home/richard/bin/qgis_/master/debug"
> Really unsure which ones are needed or used :-(
> Regards,
> Richard
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
