[QGIS-Developer] Not seeing geometry name in browser for gpkg (gdal issue?)
Nyall Dawson
nyall.dawson at gmail.com
Sun Feb 7 15:24:37 PST 2021
On Fri, 5 Feb 2021 at 20:10, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> Hi Devs,
> Opening a Geopackage node in the browser (OR looking at the 'attributes' tab in the layer props), you can indeed see all attributes and types...
> But I miss the name/ype of the geometry column...
> When I open the same dataset in a Postgis node, the 'geom' column is shown in the attribute table (WITH it's type).
> Off course for older formats like shapefiles, the geom columns did not have a name...
> Mmm, now I see that ogrinfo also does not show it (for gpkg's..).
> BUT: the Info tab in DB Manager DOES show it...
> Especially for gpkg where you can work with (spatial) queries, knowing the name is helpful.
> Or is it not there because of some technical issue?
It's probably because geopackage has a built in limitation of a single
geometry column only, as opposed to postgis/spatialite etc which can
expose multiple geometry columns.
> > Is this something easily added for gpkg?
Probably it's been deliberately removed because of the above reason
and it's just a matter of removing/disabling the expection which is in
place for gpkg...
Nyall
> Create FeatureRequest?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
